RV.Net Open Roads Forum: ? for the DP guys that run under 5 k a year
 > ? for the DP guys that run under 5 k a year
Wild One
babylon new york
Posted: 06/20/12 03:20pm Link  |  Print  |  Notify Moderator
I normally run about 2500 to 3000 miles a year. I only have to do one oil change a year in my current gasser. I own a tractor trailer with a c15 cat in it and regularly change the oil in it every 5 K and my dealer tells me I'm waisting my money I should run it to 10k before I pm the truck. It would take me 2 seasons to get to 5 K on a DP coach . Would you be ok going that long ? It usually runs me about 500 for a pm service on the tractor . That includes all filters , oil, lubing the chassis, adjusting the brakes and clutch(wouldn't need that on the coach) check all lights top off all fluids and air pressure in tires. Just trying to figure expenses on an annual basis before I make the move. Before you tell me I don't need a DP , I know that already its a want. Thanks in advance for your opinion.
95 Holiday Rambler Endeavor
bsinmich
Holland, MI
Posted: 06/20/12 03:55pm Link  |  Print  |  Notify Moderator
I don't like leaving oil that has been run and has contamiinants in it to be left sitting over the winter. I change my oil the last thing before storage each fall. That is one of the reasons I don't want a DP myself.
1975 GMC Eleganza II & 1995 Roadtrek Versatile. Both old enough to vote and drink (gas)
somarmd
Upstate NY
Posted: 06/20/12 03:57pm Link  |  Print  |  Notify Moderator
We run almost 5k miles per year and have been considering not changing each year. However, I am concerned that may be a problem for the extended warranty?
I look forward to read other thoughts too.
07 Monaco LaPalma XL 34PDD
2002 Jeep Wrangler Sport Toad
Blue OX Tow Bars and Base Plate
Patriot Brake system
Sully2
Cincinnati
Posted: 06/20/12 04:01pm Link  |  Print  |  Notify Moderator
I change per mileage and NOT by the calendar. I DO send a sample off to Blackstone to analyze. Their typical comments are to "drive it more".....*S*
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
SolidAxleDurango
OK, USA
Posted: 06/20/12 04:28pm Link  |  Print  |  Notify Moderator
I only put 4K on my Dodge PU with CTD last year... I change my oil 1x a year... I don't consider miles since I"ll never get to the recommended 7.5K/15K mile suggested intervals.
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 "> ) 14 Arctic Cat Wildcat 1000
LoneCowboy
Colorado
Posted: 06/20/12 04:02pm Link  |  Print  |  Notify Moderator
I too had a tractor trailer, and it only went just under 5000 miles per year (you know, HVUT and all) and I only did a PM once every two years, 10 to 12,000 miles.
Even the mechanic said that was fine.
I don't know that i would leave it 4 or 5 years, but every couple years is certainly fine.
Triker33
Homestead, FL
Posted: 06/20/12 04:07pm Link  |  Print  |  Notify Moderator
I change my DP oil every other year for over the last 10 years.
Have 6-7K on it then. Cummins says change at 15K miles or 1 year.
I do it myself. I figure it will still outlast me by many years.
Changed oil, filter, greased, and changed both fuel filters.
Only cost me for parts $140.61
Have the fuel filters now on a 3 year replace time. Grease chassis every year.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
Blaster Man
Posted: 06/20/12 04:25pm Link  |  Print  |  Notify Moderator
My concern is the warranty. I run about 7/8k a year, but Cummins says to change it annually or 20k. I do it annually just in case there is a problem.
2014 American Eagle
wny_pat
Western NYS
Posted: 06/20/12 04:37pm Link  |  Print  |  Notify Moderator
Just what are those contaminants going to do while sitting in the oil pan over the winter? They are not going to multply. Not going to turn into anything else. They are not going to escape. Not going to eat thru the oil pan. They are still going to be there in the spring just like you ran it yesterday.
“All journeys have secret destinations of which the traveler is unaware.”
David0725
Posted: 06/20/12 04:32pm Link  |  Print  |  Notify Moderator
I use amsoil And just get it tested my cummins has been 40,000 miles befor a oil change even then it came back good and looked new! but change it anyway.
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
