RV.Net Open Roads Forum: Fifth-Wheels: How to level on unlevel ground
 > How to level on unlevel ground
philtrains
Downers Grove, IL
Posted: 06/20/12 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Another new question. I have dual axels on my trailer. If the ground slopes to the right and I want to level the trailer do I have to put "pads" or "boards" under both right tires or just one?
In other words, can the rear right tire be unsupported and hang in mid air? Thanks.
2012 Prime Time Crusader 260RLD
2011 Ford 250 diesel crew cab, FX4, 6.7 liter, 3.73 rear end.
hallock5
Posted: 06/20/12 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
For best results, both. Then give your spouse a 6 pack and see how they fare inside.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
ch-ta
MN
both.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
AZ T&T
Mesa, AZ
Posted: 06/20/12 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Both is best.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Chuck&Gail
In the Colorado Mountains
Posted: 06/20/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Both, and then IMO put a Rotochok between them to be sure they don't roll off. at least if you unhook.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
wandering1
Posted: 06/20/12 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Both.
HR
SailingOn
Central Texas
Posted: 06/20/12 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Raising only one tire, you put more weight on that tire and wheel.
I'm sure the rig will tolerate that.
Well, pretty sure.
skipnchar
Topeka or somewhere else
Posted: 06/20/12 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Not very likely you will ever be trying to camp on ground that is THAT much out of level. Iti would need to be about eight to ten inches out of level for that to be possible. If you DID level that way it would not be very stable and would likely have a TON of bounce in the suspension.
christopherglenn
a little over an hour from Yosemite
Posted: 06/20/12 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
You can level one or both tires, as needed - Both tires need to be supporting weight!! If one is hanging in air, the other is overloaded by 70-100%.
I have 3 axles, and level with 2x8's, 0.5 inch for each board. If I am one inch low, I use 2 boards, the third tire is on its own. If I am two inches low, one tire gets 2 boards, the others get one each.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Cool Canuck
Winnipeg, MB, Canada
Posted: 06/20/12 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a trick and this is for 2 axle trailers with leaf spring suspension. If you have, say 2 inch boards and put one board under each tire, you will raise that side up 2 inches. If that wasn't quite enough and you want to raise it 1 more inch for a total 3 inches. Place one more 2" board under 1 tire only. By only putting the board under one tire it will raise the unit by 1/2 of the thickness. In this case, 1".
For 3 axle trailers you can get into some arithmetic. 1/3 for each tire.
I don't think this works for torsion bar type axles and it's probably inadvisable.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
