RV.Net Open Roads Forum: Fifth-Wheels: How to level on unlevel ground
 > How to level on unlevel ground
Mote
Westport, indiana
Posted: 06/21/12 04:14am Link  |  Quote  |  Print  |  Notify Moderator
I always put two tires on the boards. I bought a 12' 2x10, cut it so I have two 6' long boards. I can tell by how far the level bubble is off center if I need stack two or one board to level. Then just back up the tires onto the boards. It works great and I transport the boards in the truck bed.
1996 Dodge Ram 2500 extended cab 2wd, Indy 500 edition Cummins diesel
2002 Jayco 325 BHS
Bill1374
northern New York
Posted: 06/21/12 06:00am Link  |  Quote  |  Print  |  Notify Moderator
definitely 2 tires
And Skip, we're heading to a state park in northern NY next week (we've been there before) where I'll have the uphill side dug in about 5 inches and the downhill side on 4 inches of board, not 2 xs but a full 4 inches. Had to build a platform for the steps too. Welcome to the Adirondack mountains.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
Itching2go
Indiana
Posted: 06/21/12 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Interesting to hear what other folks do. Had a first-time situation just a couple of weeks back when I leveled with two, 2x6x12's on one side of the fiver (total lift of 4 inches), and ended up binding up the hitch, even though it's a swivel! The rig was so 'tilted' that the bottom of the fiver bedroom was resting on the truck's bed rail (and that's with a normal 6+ inches of clearance). Ended up having to use a couple of pieces of 2x6 I use for my stabilizers under one of the rear tires of the truck to relieve the bind. Was the only way I could release the hitch. First time that had ever happened to me.
Just sharin'....
bpounds
Whittier CA
Posted: 06/21/12 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Cool Canuck wrote:
Here's a trick and this is for 2 axle trailers with leaf spring suspension. If you have, say 2 inch boards and put one board under each tire, you will raise that side up 2 inches. If that wasn't quite enough and you want to raise it 1 more inch for a total 3 inches. Place one more 2" board under 1 tire only. By only putting the board under one tire it will raise the unit by 1/2 of the thickness. In this case, 1".
+1 and well explained. I only carry 2x lumber, and if I only need to raise 1", I just block under one tire. Gives me a perfect half block lift.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
ol Bombero-JC
Posted: 06/22/12 04:04am Link  |  Quote  |  Print  |  Notify Moderator
For 3 axle trailers you can get into some arithmetic. 1/3 for each tire.
I don't think this works for torsion bar type axles and it's probably inadvisable.
Canada is "up" from the USA - so . . .
Always add more boards on South facing side if parked in E-W direction.
USA do the opposite.
Aussies add boards to the roof.
christopherglenn
a little over an hour from Yosemite
Posted: 06/22/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Maybe on a globe, but on a flat map do they still need them on the roof?
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
rattleNsmoke
Western Conn.
Posted: 06/22/12 11:45am Link  |  Quote  |  Print  |  Notify Moderator
This is TOO funny....*lmao. Happy Fa-riday!
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
