AikenRacer
Aiken, S.C.
Just got a new class A tag. Got it home and tried the nav unit on the Jensen radio system. It is a VM9022M. Can't get the nav unit to work. Before I call Thor, does anyone have any experience with this unit?
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
sch911
Rochester Hills, MI
Sorry to hear about your issue. Why not take it back to the dealer rather than call Thor? If you need to call anyone I'd be calling Jensen.
BTW: Did you do a thorough PDI? This should have been caught by you and fixed by the dealer before you took delivery....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
ecoast
NW NJ's Highlands
I have a 9424; similar.
what is it doing/not doing?
Where is the antenna mounted?
owner's manual:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/VM9022_DOC_OM.pdf
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
AikenRacer
Aiken, S.C.
Going back to dealer out of question. They are in New York, I am in South Carolina. I called Thor and they emailed me the manual they have which isn't the same exact one. Yes, I did a PDI and as typical, I had to do most of the teaching. The screen displays the camera, radio, nav, etc. The nav icon does not allow you can't select it. Appears to me that it may be missing part of the unit that was on the spec sheet. If I can't resolve it, I'll take it to a nearby Camping World, that is the group I bought it from. I am still talking a half to full day to do that.
Executive
Are you using the remote....  ...some features are only available with the remote control...just a thought....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
09Sam
Colorado
Had the same thing. Above the instrument panel is a removable cover. Under that look for the Jenson box (black if I remember correctly) that is attached to the framing and you will find the memory chip that needs to be inserted into the box. Mine was secured with electrical tape. Once I plugged it in my nav. system it worked just fine.
2012 Tuscany 42RQ
DW, mini Dachshunds Trudy (Nov 25th traveled to the rainbow bridge), Emma, and Lexi
AikenRacer
Aiken, S.C.
Thanks, I'll check both...
