Nmoneaux
Home
I had to cut the coroplast under my keystone challenger to repair black tank. Where is the best place to buy the tape for coroplast.
352
Oxfofd, Fl
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters
just a good ole southern redneck country boy
Come visit with us and swim with the Manatees
agesilaus
North Florida
Eternabond will probably work
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
downtheroad
Pacific Northwest
I used Gorilla Tape (Home Depot, Lowes). It is still holding.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
daamac
Or cut a 4" wide piece of 3/4 plywood of an appropriate length, slip the plywood behind the slit you had to make, and screw the coroplast to the plywood. Cover the seam with spray foam - paint it black when dry to make it look pretty.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
ch-ta
MN
no experience with the Awning repair tape, but might work???Awning Tape
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
michael8rc
Here
Tried eternabond tape once and it fell off a month later.
1998 Dodge Club Cab 4x4
2010 Wildwood 292FKDS
ScottG
Bothell Wa.
I've had mixed results with Gorilla tape too. I guess al you can do it try it and see. FWIW, it helps if you clean the area up real good with alcohol.
Scott, Grace and Wesly
H0NDA eu2000i
azjeffh
Chandler, AZ
Another option would be to make it removable (if you need access again). I have had to change out dump valves and used velcro to secure the coroplast. Next time I need access, it's ready.
Jeff
Wonderful wife Robin
05 F250 Supercab PSD w/Tow Command
05 HR Savoy 29RKS
Cool Canuck
Winnipeg, MB, Canada
I ran 1x4s across so they sat on the frame and then stapled the underbelly to it. Keeps it from sagging. I covered the seam with Gorilla tape, however, that tape isn't the best answer.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
