RV.Net Open Roads Forum: Fifth-Wheels: Damage to truck bed by trailer tongue
 > Damage to truck bed by trailer tongue
greende
Syracuse,NY
Posted: 06/21/12 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
larry_kruzan wrote:
Any difference in material thickness? Sorry about all the questions, I'm learning.
Don't think so. Back of pinbox cut at 45° angle.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
Chiefcpo
Huntsville, Alabama
Posted: 06/21/12 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Same problem with mt Big Sky 3625re and I just let it ride as it is only a small nick at this time but might look at the cutting off the end to stop any more nicks. Thanks for the suggestion as in my 2011 F350 drw long bed it has the resse 24K factory installed so no height adjustment there.
Good luck Happy camping to ALL.
Hamops
Oshawa, ON, CA
Posted: 06/23/12 04:18am Link  |  Quote  |  Print  |  Notify Moderator
When we bought our 5vr, I had the dealer raise up the pinbox to the top level, for two reasons. The first reason was to lower the front end of the trailer to level it out and the second was for the very same reason that this thread was started. I'm able to get full swing clearance (until I crush the truck cab) over the truck bedrails on a level surface whether the slider is in or out.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2006 Cruiser CF30SK.
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera, JT StrongArms
luvlabs
Frederick, MD
Posted: 06/23/12 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Larry,
Does your trailer have an extended pin or one that comes straight down (more or less)? Extended pin boxes hitting the side of your box are not all that unusual. The best bet is to replace the extended pin box with a more conventional one.
2012 Tiffin Allegro 32CA
2012 Honda Fit
joebedford
Jasper, Ontario
Posted: 06/23/12 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand you comment. Raising the pinbox and getting more clearance seem to be complete opposites to me. Please explain.
LOWERING the pinbox giving more clearance I understand...
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
kennethwooster
Perryton Tx USA
Posted: 06/23/12 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I did the same thing several years back with a different trailer and hitch. If I remember correctly I just raised the hitch one bolt hole. That worked. I'm also pulling a 31Ksls Cameo. It has a Mor Ride pin box, and I have the Pullrigh SG in hitch. Great combinition and all problems are solved.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
Washboy
Denver, CO
Posted: 06/23/12 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
If the pinbox is longer than 1/2 the width of the truck bed, you're likely to have issues in tight turning situations.
I "parked" my Cameo on the top of the right bed rail years ago...backing into an inclined camping spot. After that experience I realized that I'd nicked the left bed rail at least twice backing into my own driveway.
I replaced the extended pinbox with one that's 18" shorter. I can now jack the rig past 90*...if absolutely necessary. I cannot, however, hitch with the OEM tailgate lowered because it will contact the front compartment door.
"If you don't know where you're going, any road will get you there."
2003 GMC Sierra SLT ExtCab 3500 D/A 4X4
2003 Carriage Cameo LXI F34CK3
soling2003
Federal Way, WA
Posted: 06/23/12 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same truch as you but with the 18,000lb hitch and it has height adjustments. Are you sure yours doesn't?
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
Hamops
Oshawa, ON, CA
Posted: 06/24/12 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I suppose it's how you look at it. The hitch was at it's highest level and when the trailer was hitched, the front of it was high and not sitting level. I had the dealer move the pin box higher up into the box mount so that the front of the trailer was lowered to level it out. With hitch at its highest level, the pinbox easily clears the bedrails.
joebedford
Jasper, Ontario
Posted: 06/24/12 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
OK I understand now. Sorry for being slow. You weren't talking about making more clearance for the body of your RV you were talking about the frame where the pin box attaches.
It never occurred to me that there might be combinations out there where that would be an issue. Mine doesn't even come close.
