driveby
Vancouver BC Canada
If if makes you feel any better a good friend just bought himself a long distance Trawler. 7400 gallon tanks (there are a few). Imagine his sticker shock on first fill
Of course he can go to Hawaii from Vancouver + on that fill
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
roam1
Gulf Breeze FL
We took on 8000 gallons in Cabo once.....
Meter on the pump turned over at 1000 so the gentleman just kept track on a scratch pad, I kept track in my head.....
When he said 9000 gallons I asked to see the pad, counted 8, and said I'll pay you for 8000 and no tip!
Luckily for you guys with big tanks the meters go higher here!
Ivylog
Blairsville, Ga. USA
And we thought it hurt when we fill up. At least we get Miles per Gallon, NOT GALLONS PER MILE.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Yankee Clipper
Cairo, GA
My old rig has the distinct advantage of large tanks: cargo water (100 gal), sanitaries (50 gal each), and fuel (75 gal). The real issue is that if they are all full, I'm WAY over GVWR.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
bluwtr49
Green Valley, AZ
Yankee Clipper wrote: My old rig has the distinct advantage of large tanks: cargo water (100 gal), sanitaries (50 gal each), and fuel (75 gal). The real issue is that if they are all full, I'm WAY over GVWR.
Good news though is that it's not likely you will have ALL the tanks full while traveling.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
MandalayJim
Southern Arizona
Previous moho had 100gal tank and present moho has 150 gal tank.It's nice to go 800+ miles before looking for fuel.
In the end the $$ spent is the same whether you fill a small or large tank.
Mandalay RV Forum
Jim Larocca
'08 Mandalay 40G
425hp Cummins ISL w/rear rad.
FMCA & Good Sam
bsinmich
Holland, MI
My daughter & SIL just bought a 1982 Bluebird. They were a little shocked at the 265 gal. tank. They figure they will fill up once a year and then pay off the mortage by next year again. Since we are all going to Canada next month I will be the only one stopping for gas in the MH.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Rich D.
New England
grldst wrote: We have a 200 gal tank in our "Monaco" and can comfortably do around 1100 to 1200 miles between fills.
As "Rich D" knows, I don't think there are any units that can beat the "Bluebirds" and their 300 gal tanks.
Yep, With the large tanks it hurts more but less often!!!!
Rich D. Wanderlodge M450 LXi
ArchHoagland
Clovis, CA, USA
bsinmich wrote: My daughter & SIL just bought a 1982 Bluebird. They were a little shocked at the 265 gal. tank. They figure they will fill up once a year and then pay off the mortage by next year again. Since we are all going to Canada next month I will be the only one stopping for gas in the MH.
I'd LOVE to have a 265 gallon tank.
I really dislike stopping for gas.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Alaskan Class C
Anchorage
My 78 itasca has 90 gallons 50 main 40 aux. Ive only been on one long trip but it looks like i can go about 500 miles or so which is nice to only get a few gallons inTok at 4.70 a gallons insread of alot of gas in Tok And more in Glennallen like my olfpd rig with only a 40 gallon tank. Gas in anchorage has dropped to 4.07 now and seems to be falling daily almost. Id love to see 3.xx gas soon here....
1978 Itasca, It's old but I own it....
