RV.Net Open Roads Forum: General RVing Issues: A/C's and roof vents
 > A/C's and roof vents
SKIPCAROL
COSBY,TN
Posted: 06/21/12 01:22pm Link  |  Print  |  Notify Moderator
Any suggestions here? We're parked in the sun...100 outside and have 2 A/C's. What's more effective, having the roof vent (with or without fan) open so hot air on ceiling can escape or keep all vents closed?
Carol, Skip & Buddy the Mutt
2005 Four Winds Hurricane 32R
2008 Chevy HHR Toad
SooperDaddy
Posted: 06/21/12 01:27pm Link  |  Print  |  Notify Moderator
Make a note of the temp and try it. Get the exhaust fans blowing out the hot air first, than shut them and run the A/C's on high.
But remember that the roof top A/C unit does not cool incoming air, it cools the air already INSIDE the RV.
Open the awning, park under shade trees, get some foil backed bubble wrap for the windows and roof vents at Home Depot and start up the A/C early in the morning when it's cooler also helps.
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
Old-Biscuit
Verde Valley
Posted: 06/21/12 01:44pm Link  |  Print  |  Notify Moderator
Vents open.......AC cooling inside air.......cooler air being pulled outside.
Didn't your Mom every yell......."Where you born in a barn"? [emoticon]
RoyF
Fayetteville Arkansas
Posted: 06/21/12 01:49pm Link  |  Print  |  Notify Moderator
Just thinking out loud, but the air that is exhausted out the roof vents has to be replaced by what? The replacement air has to come from somewhere, and the somewhere has to be the outside. Maybe around the door, maybe the windows don't make complete seals. So the incoming air will be 100 degrees. So I think that you shouldn't run the exhaust fans.
pulsar
Lewisville, NC
Posted: 06/21/12 02:47pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
JayWalker2009
I'm not really a
Posted: 06/21/12 02:55pm Link  |  Print  |  Notify Moderator
Keep the vents closed. Air that is hotter than what is already in the RV is going to come inside the vents.
wilcamp
Belmont Co., OH
Posted: 06/21/12 03:37pm Link  |  Print  |  Notify Moderator
Just had trouble with our AC freezing up after a couple hours. Service tech pointed out that these units cool, in part, by dehumidifying the inside air. This process may take a while, depending on the relative humidity of the interior/exterior air mass. He advised that all windows and roof vents need to be securely closed, so as not to allow in addidtional hot/humid air. All AC vents must remain completely open. Closing one, even partially, will impede the flow of cool air, and promote the freeze-up of the coils.
Wil, Tara, Nakeeta (Alaskan Husky 9 yr.-old), and Keeko (Jack Russel/Chihuahua mix 5 yr.-old)
2013 Jayco White Hawk 27 DSRB; 2010 Dodge Ram 1500 TRX4 Crew Cab 5.7L Hemi w/ 3.92 rear axle
jassrnj
Bath, PA
Posted: 06/21/12 03:50pm Link  |  Print  |  Notify Moderator
It should be the same as your home. I would not run my home AC with windows open. Close all windows and vents.
hallock5
Posted: 06/21/12 04:06pm Link  |  Print  |  Notify Moderator
Make sure the sparrows and crows perching on your vents leave a tip..[emoticon]
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
AO_hitech
SF Bay Area
Posted: 06/21/12 04:14pm Link  |  Print  |  Notify Moderator
Technically it is most efficient to leave the vents open until the inside temp is equal to or lower than the outside temp. Practically it is just best to close everything first.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
