I read on heare or asked before dont remember how do you adjust the xcreen door so that it dosn't drag on oposite side of hinges. I adjusted it once before but cant remember how I did it. Moved to Tech Issues forum from DIY.
last
edited 06/21/12 02:47pm by an administrator/moderator *
View edit history
CREATO wrote: I read on hear or asked before don't remember how do you adjust the screen door so that it doesn't drag on opposite side of hinges. I adjusted it once before but cant remember how I did it.
I think I told you to bend the Z hinge to hold it away from the jamb on the hinge side. You or others usually the ladies hang onto the screen door for safety and it usually makes the screen door hit the bottom of the aluminum threshold. I just did ours last week by pulling under the lower hinge with my fingers.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
www.campingworld.com/shopping/item/screen-door-cross-bar/35872
Purchase two of these, and install one above the sliding latch door & the other just below. They work GREAT! They will assist some folks who have trouble going in and out. This last summer I installed several of these setups on rigs. Best bet take your time measure, calculate & measure(use pencil for making marks) again then drill your pilot hole(slightly smaller than the screws that it comes with)its soft metal and will expand torquing the screws in making them stiff. The cross support of two of these keep that continuous pushing down on the opening latch from un-square-ing the door. Us the first install(bar) as a template to the second one you put on the door. Its an easy project with Great results.
Blessings,
Sometimes dragging is function of your set up. When I level up sometimes and the frame gets a little cock-eyed and the door will drag.
The turnbuckle/rod solved that problem.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
chevman
That is what you told me, Works fine now . Have the 4 grand grand kids with us on vacation for 10 days in northern Minn. having to remind them not to hang on tbe screen door.
Thanks all
