RV.Net Open Roads Forum: Travel Trailers: tongue chock/pad
 > tongue chock/pad
skipnchar
Topeka or somewhere else
Posted: 06/21/12 09:22pm Link  |  Print  |  Notify Moderator
You can use ANYTHING or nothing (if you have a sand pad on the jack). Do what works best for you.
Ole Man Dan
Gadsden, Alabama
Posted: 06/21/12 10:57pm Link  |  Print  |  Notify Moderator
I use pieces of 6"X6" about 1' long under the stabilizers and under the jack. Cheap and sturdy.
When they get too worn, and start to split, they go into my fire-pit.
NanciL
Bakersville, NC,/Key Largo FL
Posted: 06/22/12 04:40am Link  |  Print  |  Notify Moderator
I made up a box 10" square for it, and also made up four slightly smaller ones for the stabilizers.
I found many times I need extra height for the tongue jack to get it on and off the hitch ball, and I also found that the more spread out the stabilizers are the less wobble there is in the trailer, and putting them up on the boxes solved that problem.
Jack L
Jack & Nanci
Padlin
W. Ma.
Posted: 06/22/12 05:13am Link  |  Print  |  Notify Moderator
Peice of Bass 8x8 about 12" long, scrap from carving.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
c3saving
East Coast
Posted: 06/22/12 05:28am Link  |  Print  |  Notify Moderator
Jack L
We have also found that we need to raise the tongue jack extremely high in order to get the hitch on and off the tow vehicle. I happened to be on Youtube and found a segment from Recreation in Motion. A viewer had several 2 x 4's which were cut where each piece was smaller then the previous. Once nailed together it created a stair-step looking creation. I did not create a stair step. My pieces were all 4 to 6" smaller similar to what I had seen. I centered them all on the 1x6 piece. I am not an engineer, but I thought the support would be better if the wood was centered on the base. We will be trying it out later on today. It's a quick fix and probably won't last long because the bottom 1x6 is the only pressure treated piece. We will eventually purchase an electric tongue within the next several months.
I'll take a picture later on and post it. If it doesn't work, nothing lost. The wood was going to be recycled anyway.
stevemorris
ontario
Posted: 06/22/12 05:19am Link  |  Print  |  Notify Moderator
last year i used a nice big (6 by 12 by 12) chunk of walnut, over the winter i turned it on my woodlathe and made a nice bowl as a momento of the trip
i'll do another this year!!
tomdinwv
WV
Posted: 06/22/12 05:24am Link  |  Print  |  Notify Moderator
I use a piece of railroad tie about 12" long. I did use one of the red cone jack stands like others have suggested but mine split from the bottom and continued to split about half way up the cone. I had to toss it in the trash.
usmc616
Orange County, New York
Posted: 06/22/12 05:32am Link  |  Print  |  Notify Moderator
Chuck&Gail wrote:
I love my FlipJack. I chock WHEELS, not the tongue jack.
X2
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.">
pasusan
Northernmost PA
Now that's original! [emoticon]
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
*** Also a 2004 Roadtrek 170 (See pic in Profile) ***
Trip Pics
rgolding
Southern Illinois
Posted: 06/22/12 06:47am Link  |  Print  |  Notify Moderator
I carry one of those drive on jacks "Trailer Aid", that allows you to change a flat on one axle by pulling the trailer up on to the wheel on the other axle on the same side. Not liking to carry stuff that doesn't get used much, I use this under the trailer jack wheel when camping. At the house, when the trailer is in storage, I use a concrete block.
Smooth Sailing,
Ric and Jan
Southern Illinois
2016 Jayco Seneca 37FS "Low Key"
 > tongue chock/pad
