RV.Net Open Roads Forum: Fifth-Wheels: Balance new tires Yes or no
 > Balance new tires Yes or no
LostinAZ
At Home
Posted: 06/21/12 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
yes!
Artemus Gordon
Redding California
Posted: 06/21/12 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Anytime you return from California, you should balance your tires.
Mile High
Denver, CO
Posted: 06/21/12 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
smkettner wrote:
Yes, lug centric.
X2 Lug centric requires an adapter on the machine to mount the tire to the balancer through the lug holes rather than the through the hub. Not all shops can do that so be sure and ask. If you get a glazed look - ask again until you get a confident answer. You may have to go to a different shop if they don't have the adapters.
Discount Tires had the adapters, but the techs that know what they do are not very common.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Cummins12V98
on the road
Posted: 06/21/12 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
You have a heavy rig, what tires are you replacing and what with?
Balance for sure.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
NorthernLimits
Michigan
Posted: 06/21/12 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
Lug centric balancing is pretty rare. better, sure but rare for any tire balancing, car, truck or trailer.
retired-tech
flint mi
Posted: 06/22/12 07:36am Link  |  Quote  |  Print  |  Notify Moderator
not only is it easier on the trailer if you balance the tires, but it take power to spin a tire that is not balanced.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
Jim-Linda
Livingston, TX
Posted: 06/22/12 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Confusious say, if it rotates, balance it.
Jim
christopherglenn
a little over an hour from Yosemite
Posted: 06/22/12 09:51am Link  |  Quote  |  Print  |  Notify Moderator
I put 6 g614 on yesterday, all were balanced through the hub, not the best but better then nothing.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Gray Fox
Swansea Ma. USA
Posted: 06/22/12 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the tire replies, I will get them balanced tire size 235/85/R16 E. I'm looking at Michelin XPS Rib. Or maybe Goodyears
Love to hear any comment!!!
Gray Fox
2005 F350 4x4 Diesel Lariat
2009 HH-LS 34.5 RLTG
Always keep moving so you don't seize up.
fla-gypsy
North Florida
Posted: 06/22/12 11:16am Link  |  Quote  |  Print  |  Notify Moderator
I always do. If you have ever seen an unbalanced tire on a trailer flapping around it is easy to understand why.
