RV.Net Open Roads Forum: Fifth-Wheels: Balance new tires Yes or no
 > Balance new tires Yes or no
Allworth
Orlando, FL
Posted: 06/22/12 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Always! Dynamic balance.
by the way; you can go to a 245/75 which is more available in Load Range E. B.F.Goodrich Commercial TA is a good balance of cost and performance.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
Gray Fox
Swansea Ma. USA
Posted: 06/22/12 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Will balance for sure. I have checked my rims to see if I can go to "G" rated tires, this is what I found on the back side.
1. H 1027 244
3860 LBS
2. Dot-1 16X6 J?
3. 67732
0466 HD
4. MFG by MS 21318CA C
Made in China TCJ M
Does any know what all this means ? Nothing that says 80PSI or 110PSI.
The tire that blew was Uniroyal Laredo LT235/85/R16 120/116DM&S
Gray Fox
2005 F350 4x4 Diesel Lariat
2009 HH-LS 34.5 RLTG
Always keep moving so you don't seize up.
Duck
Miami Lakes, Fl
Posted: 06/23/12 06:04am Link  |  Quote  |  Print  |  Notify Moderator
1. H 1027 244
3860 LBS
2. Dot-1 16X6 J?
3. 67732
0466 HD
Made in China TCJ M
I had a 2008 HH LS and the rims were rated for the G tire.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
Mile High
Denver, CO
Posted: 06/23/12 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Just curious what are your axles rated? Should be on the tag on the left front of the trailer under GAWR.
The Uniroyal tire that blew was only rated to 3,040 lbs., which if correctly installed means you would only have 6K rated axles, or improperly installed if you have 7K axles. If you have 6K axles, the XPS ribs are fine, or Firestone Transforce, or any number of LT truck tires and you only need to inflate to 80psi.
7k axles should run the G, which leaves you with some china tires or the Goodyear G614.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Gray Fox
Swansea Ma. USA
Posted: 06/23/12 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Mile High I will get back to you with some numbers later today.
chevor
US/Canada
Posted: 06/23/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Im trying something new and putting Counteract balancing beads in my new tires. I have had problems with tires needing to be rebalanced
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 497,500 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
cwstanley
Goldsboro, PA, USA
Posted: 06/23/12 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Chevor, you beat me by a couple minutes, DYNA-BEADS best thing running out there, we use them on all things, custom motorcycles, big big trucks and etc. they work great & don't have to worry about the weights falling off etc..
and very in-expensive as a whole.
just my two cents worth but they do work good.
2008 F350 Dually, Lariat, 4X4, CC
2014 Sierra 376BHOK
Wife, son & 2 Brittany Spaniels
Gray Fox
Swansea Ma. USA
Posted: 06/23/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Mile High
This is what I have for the GAWR/PNBE
Front 3,174 KG
AVANT (7,000 LB)
Rear/ 3,174 KG
ARRIERE (7,000 LB)
GVWR/PNBV: 6,575 KG (14,500 LB)
Does this mean the front & rear axle are 7,000 LBS and the GVWR is 14,500 LBS.
I got these numbers right of the tag on the Tr.
Mile High
Denver, CO
Posted: 06/23/12 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Gray Fox wrote:
Mile High
Front 3,174 KG
AVANT (7,000 LB)
Rear/ 3,174 KG
ARRIERE (7,000 LB)
Yes. However, the GVWR seems low to me - it should be closer to 15,500 lbs because you get to add the pin weight and the axle rating, but either way it looks like you have 7,000 lb axles.
Just know that by putting on the XPS ribs at 3,040 lbs a tire, you are actually limiting your axles to 6,080 lbs rather than the 7,000 lb capacity. You might weigh the rig to see where you really stand on the axles and the total weight.
You can use a CAT scale - weigh the whole rig, then disconnect and weigh your truck. subtract the truck from the total to get your trailer gross weight, and the initial weigh had the axle weight as one of the numbers. Once you have that, you can make the right choice on tire load range.
ol Bombero-JC
Posted: 06/24/12 01:29am Link  |  Quote  |  Print  |  Notify Moderator
Artemus Gordon wrote:
Anytime you return from California, you should balance your tires.
Especially if you spent any time on I-5. .
BTW: Yes - balance no matter where you are/live.
