RV.Net Open Roads Forum: Beginning RVing: route to Salinas
 > route to Salinas
Sandra
Lake Arrowhead, Ca.
Posted: 06/21/12 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Need a route from Petulma Elks to Salinas Elks.
Don't want to go over the Golden Gate bridge.
36' motorhome with a tow.
Thanks
jbarry
California
Posted: 06/21/12 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Not a lot of choices...
South out of Petaluma on 101 to 37 to Vallejo.
I-80 west to I-780 south through Benecia to I-680 south through San Jose to 101 south toward Los Angeles.
or
South out of Petaluma on 101 to Exit 451B for I-580.
Keep left at the fork and follow signs for I-580 Richmond/San Rafael Bridge. Merge onto I-580 east.
To I-880 south to San Jose.
I-880 south to 101 south toward Los Angeles.
I would do the first one myself. Don't like the Richmond/San Rafael Bridge (it's an over/under, and going east you'll be under.) Also don't like driving the 880.
rolnhome
Casa Grande, Az
Posted: 06/21/12 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Never mind I read wrong town into your post.
We're in Arizona
Pokey2
Bel Marin Keys, CA
Posted: 06/22/12 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I, too, would opt for jbarry's first suggestion.
christopherglenn
a little over an hour from Yosemite
Posted: 06/22/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
101 south, 580 east, 80 west, 880 south, 101 south. 880 will beat your suspension, but 1/101 at the gate is under construction, who knows how the temp road is today.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
elkhornsun
Monterey
Posted: 06/25/12 12:34am Link  |  Quote  |  Print  |  Notify Moderator
Except for the short stretch across the Golden Gate bride taking Hwy 101 is a straight shot to Salinas and it is flat the entire distance. If you leave after 10:00 AM the morning commute rush into San Francisco will be largely over. In the morning there is much less chance of encountering winds coming off the ocean which usually don't start to blow until the afternoon as the inland areas heat up.
The alternative involves taking the San Rafael bridge over to Oakland and then south on Hwy 880 which is under heavy construction with new overpasses being built and then intersecting Hwy 101 in San Jose and making a very tricky merge with traffic that is coming off Hwy 101 northbound to get onto Hwy 880 southbound. It is a much longer and more stressful route than going across the Golden Gate bridge.
elkhornsun
Monterey
Posted: 06/25/12 12:36am Link  |  Quote  |  Print  |  Notify Moderator
By the way the only way to get to Salinas from Petaluma is to cross one or more bridges so it is really only choosing which one and none are particularly wide.
Jack&Kay
Santa Rosa, Ca
Posted: 06/25/12 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
We took the route from SR 101 to 37, I80, I780 to 101 in March that is described by jbary above. We weren't towing at the time, but other friends with us were and it was OK. The Benicia bridge has a toll the other way. It would cost you $15 for the GGB south-bound for an RV and towed, not to mention the construction just beyond the bridge. Jack
Jack & Kay
2007 Tiffin Allegro 28DA
Ford Chassis V-10
Blue Ox Tow Bar to a 94 Honda Accord
FMCA #F341229
Sandra
Lake Arrowhead, Ca.
Posted: 06/25/12 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advice. Made it with the route over Richmond bridge.
MarshaNichols
Salinas
Posted: 06/26/12 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I would go with jberry's first suggestion also. I live in Prunedale (7 miles north of Salinas). There is an extreme amount of construction on 101...the lanes are narrow with cement barriers. People are not driving the 55 mph speed limit...I suggest you are very, very careful through the area south from the Red Barn to Salinas proper. The turn-off for the Elk's is improved and an easy off/on 101. Have fun!
 > route to Salinas
