Uncle Wiggly
SE Colorado
Both of us have hands that are weakening from arthritis.
We have been able to work around this by different positions or aids on almost everything in our lives except our black and grey water connectors.
They are a bear to twist on and off!
I have a strap wrench that gives plenty of leverage, but it takes three hands to position it along with the hose to hook up, so it's not the solution.
Any ideas out there?
2011 Lance 2285, 2010 Mercedes-Benz ML350 Turbodiesel
rolnhome
Casa Grande, Az
Maybe it's time for a permanent macerator hookup
We're in Arizona
gbopp
The Keystone State
rolnhome wrote: Maybe it's time for a permanent macerator hookup
x2
dturm
Munster, IN
Another option is a blueline sewer hose. It has a slip on quick connect on the hose and you mount the adapter one time on the sewer outlet. One down side is you won't have a cover on the sewer connection while not in use, but it would certainly ease attaching the hose.
Blueline sewer hose.
Wills250psd
walnutcove NC
Very large pair of chanel locks? I have a pair that opens to around 6" that would only take 2 hands. One hand for the hose and one for the chanel locks. Just an idea. GOOD LUCK,WILL
PattieAM
Maryland
I have the same problem, and have a rubber mallet I use to gently tap the fitting loose or tight. I also lube the fitting with either dish soap or veggie oil.
traveylin
Rockport
My connection is recessed under the rv to some extent and awkward to reach. I found a clear extender that attaches first that is about 14 inches long and allows attachment with my hands on the out board side of the rv. The clear extender made for purpose is probably to give a visual indication of flow
Joy
Henderson KY 42420
I have to do all that stuff now since Don no longer can - I also have arthritis in my hands and cannot do those connections. My solution as stated above, a permanently mounted macerator. It is connected one time (by a younger ablebodied person) so all that has to be done at dump time is to pull out the 1" hose and twist the end into the sewer pipe then push a button! I love it!!! No more big hard to store hoses, either!
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
chuggs
I don't know about the clearances you have...but you might be able to do a simple mod to each of your fittings.
Drill an appropriate sized hole thru the fitting. Insert a carriage bolt from the inside out...threads sticking out of the fitting...Use an epoxy to glue it into place. The round top on the carraige bolt will hopefully not snag toilet paper, etc...
Screw on a handle...similar to the ones that screw onto big drills. I'm sure you can source them as a replacement part from places like SEARS...
Now, each of your fittings will have a handle sticking out, which will give you the leverage of the strap wrench...without all the hassles of needing three hands to position it each time.
dbbls
Missouri
Years ago I bought a sewer adapter wrench at Camping World. Just a few dollars.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
