RV.Net Open Roads Forum: Fifth-Wheels: Adding a Second battery
 > Adding a Second battery
pcm1959
home
Posted: 06/22/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I have a Carriage Cameo with a battery compartment that will accomodate 2 group 24 batteries. Currently, we only have one battery. I need more reserve power from the battery when the coach is in storage for the regrif and Big Foot jacks prior to each trip, so I'd like to add a 2nd battery. I do not know the exact age of the battery that came with the coach, but we took delivery in September of 2011. Is it ok to add the second battery to the current battery or should I start out with 2 fresh, new ones? Thanks, Phillip
2011 Silverado Crew 3500 SRW Duramax/Allison
2011 Carriage Cameo 31KSLS
Jacksonville, FL
fishingbob61
cookevill tn
Posted: 06/22/12 06:57am Link  |  Quote  |  Print  |  Notify Moderator
I would go with 2 group 27 batts instead of the 24, more pqwer ans more reserve, or 2 6volt golf cart batts.
Bob and Sue
40 years camping 48 years July 2011
2005 Holiday Rambler Presidential 36RLT 5th wheel
2004 Chevy 3500 D/A crew cab long bed 4x4 Dually 3.73
Honda eu3000 gen
ken white
Ohio
Posted: 06/22/12 06:58am Link  |  Quote  |  Print  |  Notify Moderator
If the batteries do not have some sort of isolation between them, then both batteies should be new and the same. If you have isolation, you can add a different battery in parallel with no issues.
2008 Dodge RAM 3500, 4x4, Quad Cab, Long Bed, DRW, G56, 3.73's, American Force 19.5's, Rancho RS9000XL Shocks, Line-X, P3 Brake Controller, Timbren upgrades, H&S Black Maxx, etc...
2012 Canyon Trail 27FREL replaced a 2007 Lance 1055...
joelc
Milford, PA
Posted: 06/22/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I also have a Cameo that came with 1 12V battery. It is best to pair the batteries with the same type and age. I will be waiting a year or two for the 12V to age a bit and then will be installing two 6 V batteries in. this will give me longer life and more power. It will also allow boondocking to be more feasable. I do not know what type of batteries I will use yet or the brand. Research will be done on this later. It will be either Interstate or a well known brand, not Chinese.
Eycom
32043
Posted: 06/22/12 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I like this suggestion. Experience is a good teacher.
RVn Full-time
mpfireman
Cook County Il
Posted: 06/22/12 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Remember when adding that second battery, you should buy two NEW batteries, as adding that second new battery to an older one will defeat the purpose of having that additional battery. You will not achieve that much of a longer stay time when having dissimilar batteries.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
skipnchar
Topeka or somewhere else
Posted: 06/22/12 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Yes you can simply add a second battery and it will work fine. for the MAXIMUM difference they would need to be the same but under any circumstances, adding a second battery in good condition will increase the amount of power available. With two fresh new batteries you would come close to doubling the power but adding a second battery may give you 75% more.
pianotuna
Regina, SK, Canada
Posted: 06/22/12 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If boondocking is the goal consider adding a modest solar system as well as the additional battery.
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
pcm1959
home
Posted: 06/22/12 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I don't think that two group 27 batteries will fit in the compartment. We don't do any dry camping. I am mainly looking for more reserve power for the refrig the day or 2 before departing on a trip.
Prior to our last trip, the refrig, along with its two cooling fans, ran the battery down enough that the refrig quit cooling. So when we got to the rig toload the refrig it was not cold and the Big Foot would not operate. It was over 90 degrees outside so I imagine that the frige coolings fans ran a lot.
Anyway, I'm just trying to the best thing so that this does not happen again. Thanks, Phillip
* This post was edited 06/22/12 08:34am by pcm1959 *
pianotuna
Regina, SK, Canada
Posted: 06/22/12 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Hi Philip,
I take it there is no way to run a cord to the RV for fridge cooling?
