RV.Net Open Roads Forum: Tech Issues: Wheel Pressure Rating
 > Wheel Pressure Rating
Papa & Mimi
Mount Pleasant, SC,
Posted: 06/22/12 10:01am Link  |  Quote  |  Print  |  Notify Moderator
My camper came with 6 ply 205/75R/15 tires on my camper. The pressure rating is for 50 PSI with a load raging of 1820 lbs.
I have found the same size tire with an 8 ply rating. BUT it takes 65 PSI.
Will the wheel (that the tire is mounted on)take the 65PSI pressure required of the 8 ply tire?
Where can I find out that information.
Thanks and God Bless
Papa
Moved to Tech Issues forum from DIY.
* This post was edited 06/22/12 03:00pm by an administrator/moderator *
ScottG
Bothell Wa.
Posted: 06/22/12 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately that is usually embossed into the rim so you have to remove the tire to see it. Personally, I wouldn't worry about another 15PSI with your wheels. I don't believe it would hurt them in any way.
Scott, Grace and Wesly
H0NDA eu2000i
bob213
Fresno, CA
Posted: 06/22/12 10:45am Link  |  Quote  |  Print  |  Notify Moderator
15 lbs. doesn't seem like much but keep in mind it is a 30% increase over what that rim is holding now. If you do it, make sure you get metal valve stems or high pressure at the least.
kaydeejay
SE Michigan, USA
Posted: 06/22/12 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Your 8-ply tires will carry 1820# at 50psi.
Unless your 6-plys are overloaded you really don't need max pressure.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
christopherglenn
a little over an hour from Yosemite
Posted: 06/22/12 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Pull a rim and check. I pull a rim on everything (but my bike) just to make sure I can change a tire if need be. Wipe the inside of the rim, and the weight rating and max psi should be stamped into it.
15 psi is alot! If you have a compressor, dump 15 psi of air out of one of your tires - lower one to 35 psi. compare what it looks like to the 50 spi tire next to it.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
falconman
On The Road!!
Posted: 06/22/12 11:44am Link  |  Quote  |  Print  |  Notify Moderator
I would worry about the weight rating more than the pressure. As long as you don't exceed the weight carrying capacity you should be fine with 65 psi if its needed. Always wondered what a rim looks like that failed solely from too much pressure, anyone seen one?
Old-Biscuit
Across the USA
Posted: 06/22/12 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
A pressure vessel rating is a combination of structural design, materials used, construction methods etc. plus a safety margin due to effects of temperature.
A wheel/tire combo is a pressure vessel.
A 50 psi rating is MAX cold pressure.....pressure will increase due to rise in temperature. This is where the designed safety margin comes in.
Increasing pressures above the stamped rating eliminates the designed safety margin.
Having operated pressure vessel my whole career and witnessing the effects of ratings being ignored.......no thanks!
Do as you 'think' but ask yourself 'why have pressure ratings'.
Why would it NOT be OK to exceed weight rating but OK to exceed pressure rating
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Chuck&Gail
In the Colorado Mountains
Posted: 06/22/12 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Rating usually stamped on rear of wheel, or in valley UNDER the tire.
Personally I would not overload any of MY rims by 30%!!!!!
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
