RV.Net Open Roads Forum: Class A Motorhomes: Slide Seal Replacement
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Slide Seal Replacement
TampaSean
Tampa, FL
Posted: 06/22/12 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Hello Everyone,
Our Sun Voayger is in need of the large slide out seal being replaced. It is a single piece/length of seal, not 3 pieces if that matters. I looked at it briefly and the wire teeth/clips seem to be rusted and not holding any longer on one side so it won't be long before the entire seal fails....so how hard is it to do DYI?
Clearance between where the seal mates and the actual slide is minimal. Not certain if there are any tricks/adjustments that can be done to increase clearance.....just looking for some tips/guidance. Slides are PowerGear hydraulic slides if that helps
Thanks in advance!
Sean
Sean, Deb, Reagan, Fin & a couch potato named Yogi
2000 35' Gulf Stream Sun Voyager
V-10 w/ Banks PowerPack
FMCA F403706
03 RoadKing
Summerfield NC 27358
Posted: 06/22/12 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's not a difficult project. I replaced the one piece seal on a Holiday Rambler I had, I made 2 pry bars from old hammer handles to push the seal into place. The rusted spring clips you are seeing are inside the rubber orginally.
Go for it.
Jim and Deb
The Furchildren Abby and Baylee
USAF Retired
2001 Newmar Mountain Aire
Warr Eagle!
Bratt, FL
Posted: 06/22/12 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
My dw and I replaced ours on our HR. It is not to difficult,if you take your time and get a system worked out it goes pretty easy.
Cool Canuck
Winnipeg, MB, Canada
Posted: 06/22/12 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
A little silicon lube helps. Not difficult at all, just position the slide so it is easy to work on.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
