RV.Net Open Roads Forum: Tech Issues: How many amps per appliance?
 > How many amps per appliance?
sandy43
Hockley, TX
Posted: 06/22/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Is their a chart that shows (estimate) what each appliance uses for amps. If I use my 50 amp cord (or 30 amp cord) what can I turn on. This would be very helpful to me and hopefully others. Thanks
wolfe10
Posted: 06/22/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming your RV is 50 amp, the first piece of math is:
With 50 amp RV outlet, you have 100 amps of power available.
With 30 amp RV outlet, you have 30 amps of power available.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
pianotuna
Regina, SK, Canada
Posted: 06/22/12 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Or to speak in watts with a 50 amp RV there are 12000 watts available and in a 30 amp RV only 3600 watt may be used.
On of the best ways to find out what demand is is to use a kill-a-watt meter. For example my water heater plate says 1400 watts--but in fact only draws 1151.
watt meter
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 06/22/12 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
A 50 amp RV plugged into a 50 amp shorepower can use everything thats on the RV all at the same time.
My stick and brick home I sold only had 100 amps and never threw a circuit.
A 30 amp RV plugged into a 30 amp shorepower can use one AC at a time unless you have an Energy Management System on the RV.
You can use your microwave but not together with the washer/dryer or electric water heater. You really need to use only one high useage item at a time. Those being:
AC, Electric water heater, washer/dryer, microwave, electric heater, and last but not least, my wives turbo charged electric hair dryer.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
skipnchar
Topeka or somewhere else
Posted: 06/22/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Stop turning them on when you trip a breaker, is the easiest way to know when the circuit is overloaded.
bluebirdPT36
NE Tn
Posted: 06/22/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
watt meter
I do not own a kill-a-watt___they seem to be a handy gadget.
My question is about the wattage of your water heater. Isn't voltage an important factor on the amperage draw of a resistance load? At what voltage did you read 1151 watts? Was it significantly less than the tag on your heater?
2oldman
Wilson Creek WA
Posted: 06/22/12 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure google knows.
pianotuna
Regina, SK, Canada
Posted: 06/22/12 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I do not remember the voltage being low--and I'm a stickler and do not run items below 108 volts. Nominal in my location is 120 volts.
The number plates appear to have little relationship to reality--only once has one been within 5% of the actual measured load. I have check the meter and it is correct.
* This post was edited 06/22/12 07:59pm by pianotuna *
mena661
Posted: 06/22/12 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Here you go.
Trojan L16 6V's 740 Amp-hours
sandy43
Hockley, TX
Posted: 06/22/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Many thanks guys. Lots of good info.here.
