What Brand, size, axels, openings, ramps, windows, vents, lights inside/outside. What options do you have, on your Cargo Trailer. Pictures please? What do you store? Can you see trailer with your mirrors? Parking? Hitch & Extension.
I would like your suggestions.
I don't have an enclosed trailer, but I like Dexter and Quality brand axles with the Easy Lube set up. Many times you can get the next size larger axles at a small additional cost; say 5,000 lb axles instead of 3,500 lb axles. Also, make sure you get brakes on both axles. How much cargo weight will you be hauling?
Good Luck,
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW Our Truck Camper Photos
As above, depends on what you plan to haul. We haul wifes BIG handicap scooter, or 4x8 sheetrock or plywood, or use it for dump runs.
What Brand, Mirage Xtera
size, called a 4x8 but BE CAREFUL. I found most manufacturers cheat, and you could not put a 4x8 sheet of plywood flat on floor. With ours you can. Check BEFORE you buy that what you wish to carry will fit.
axels, one
openings, door on LEFT side, done as an option
ramps, yes
windows, no
vents, no
lights inside/outside. inside
What options do you have, on your Cargo Trailer. otion height so I can stand up inside. Also makes ramp longer so easier to load. Also spare is on wall INSIDE trailer so harder to "borrow".
Pictures please? What do you store? nope, nothing "stored" in it.
Can you see trailer with your mirrors? yes
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories I can't be lost because I don't care where this lovely road is going
Quote: 2005 F-250 XL Super Cab short bed, 4x4, 6.0 PSD, Tow/Haul 5-speed automatic, manual transfer case and hubs, 3.73 limited slip, 275/70R-18 Michelin LTX A/T-2 3650lb tires on King Ranch aluminum rims, dual 140A alternators, air conditioning, cruise control, Tow Command brake controller, lighted and powered tow mirrors, 12.5k lb tow package upgraded to 17k lb. SuperHitch with 18" extension, camper package upgraded with Torklift frame tie downs and FastGun turnbuckles, Energy Suspension bump stops and Firestone Ride-Rite air bags, Line-X coating with DeeZee bed mat, skid plates, XL convenience package, Bully step bars, hood and window air deflectors, rear mud flaps, Upfitter switches, 40/20/40 cloth split bench, Pioneer AVIC D2 double DIN GPS.
2012 Arctic Fox 811S, Fox Value Package, diamond plate, slide awning, Maxxair vent covers, 11k btu air conditioning, 2.5 kw Onan genset, dual group 29 batteries, rear quarter storage, Glow steps, dual pane thermal windows, 2-way water heater, 3-way 6 cu ft refrigerator, microwave/convection with oven delete, full wall wardrobe, 22" Pyle LCD/DVD combo.
2012 Interstate Pro-Series, 20'x8.5', 8" I-beam frame, dual 5200 lb 4" drop torsion axles, diamond plate, chrome rims with Load Range D radials, 10k lb equalizing hitch with sway control, Camping World vent cover, LED lighting, 3' RV door, front and rear door interior light switches, interior plywood walls and floor, 3 rows of Z-track rails with recessed corner D-rings.
Hi we have a 16 foot V-nose inclosed cargo trailer, a no name brand. It has dual axles, electric brakes,
a large ramp back door, a side door, interior lights, and 2 side air vents for gas fumes to disapate.
It was made to haul motorcycles. We have D rings through out on floor. It came with a cheap linolium over the plywood floor. Also sides and ceiling are finished off with white aluminum. I have put cabinets into the front V nose for gear. Also racks for our kayaks above the motorcycles. It works great to give us the extra storage with the truck camper plus everything is looked up and out of site. I put a torque lift super hitch -24"hitch on the truck which handles it well. Sorry no pictures
Our camper/truck (Lance 992 and Dodge 1 ton) with our motorcycle trailer a couple of years ago.
Sold the camper and truck. This combination worked very well.
Big touring bike fits very well in this trailer, plus tool box, jerry cans, and motorcycle clothing.
We still use the trailer, no plans on selling it. Put new tires on it this spring.
We own a Triple E Grand Touring (C Class) right now.
Not to be picky but that sure don't look look a Dodge .
Just got a CarMate double Dexter axle 7x14 cargo trailer. Using for a touring motorcycle ,2 bycycles, 2 kayaks, assorted stuff. Installed a 14x14 vent the other day. On deck for installation, a 12w solar panel with controller, battery, alarm with 2way remote, 2 small steel cabinets, kayak mounting hardware. No pics yet, this was already an upgrade from the original choice of 6x10. The space dissappears quickly. I havnt crammed everything in yet but it looks like everything planned will fit.
