RV.Net Open Roads Forum: Fifth-Wheels: mainaince for wheel bearngs
 > mainaince for wheel bearngs
bfsch1957
Bismarck
Posted: 06/22/12 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
I been told by service department techs. To grease the wheel bearings
every two years. Is that correct, and how many miles can I run before repacking.
Chuck&Gail
In the Colorado Mountains
Posted: 06/22/12 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have a dual axle with EZ-Lube hubs. Every year I hand pack one hub, so I can check brake linings and bearings. Other three hubs get slow squirts from hand grease gun into EZ-Lube fitting. I do about 8500 miles a year.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
cabanaman
florida
Posted: 06/23/12 01:25am Link  |  Quote  |  Print  |  Notify Moderator
I went 5 years and got away with it.Now I repack via the EZ lube system once a year.But that's just me.I'll be doing the brakes soon.
Retired Navy http://www.gofundme.com/carebear
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
maniac007
South Carolina
Posted: 06/23/12 02:20am Link  |  Quote  |  Print  |  Notify Moderator
Al-Ko axels says to repack every 6000 miles or once a year. Al-Ko manual here Dexter Axel says yearly or 12,000 miles. Dexter sheet here Hope this helps.
02 F350SD 7.3 CC DRW, 06 Cougar 314EFS
phillyg
Front Royal, VA
Posted: 06/23/12 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I don't worry about the mileage. I think every two years is okay. Purchase an inexpensive infrared thermometer and check your bearing and tire temps at every stop (and check your tow vehicle tires, too). What you're looking for are inconsistent temps. If three of four bearings are 140 degrees and one is 180, you need to check the one with the high temp at your earliest convenience. As I recall, bearing temps higher than 200 degrees are critical and should be dealt with immediately.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
wandering1
Posted: 06/23/12 08:00am Link  |  Quote  |  Print  |  Notify Moderator
What does your owners manual say? I think I would listen to the service department techs since they are subject matter experts in the RV service business and not just giving personal opinions based on good or bad personal experience.
HR
kennethwooster
Perryton Tx USA
Posted: 06/23/12 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I have the EZ lube axles, and not really impressed. I called Dester, and they only wanted them greased when all the grease is warm. Told me to pull trailer to warm grease. Pump slowely. All this to keep from pushing the seal out the back. Talked to a Dexter dealer in Amarillo tX and he said only grease by hand. I just repack once a year and forget about the EZ lube.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
steelpony5555
Copperas Cove Texas
Posted: 06/23/12 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Just got done doin mine. Dealer I bought the trailer from said they repacked them and checked the brakes......yeah,,,right,,,,,NOT. I take my trailer into a trailer sales place for any running gear problems. We have lots of them here in Texas that sell horse and stock trailers. Cost me $100 to have the bearings repacked and the brakes adjusted. For $100 it ain't worth me even getting my tools out much less laying in the dirt in 100 degrees. Just got to find one that you can trust.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
Puddles
Lafayette, Indiana
Posted: 06/23/12 09:42am Link  |  Quote  |  Print  |  Notify Moderator
That dealer in Amarillo gave you Very Good Advise...
HTML
rfryer
Phoenix
Posted: 06/23/12 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
My manual says yearly or every 10,000 miles. I ignore the mileage, it's not that far where I like to camp. Even Canada's only about a 3000 mile trip. I first started greasing the bearings yearly, but found they really didn't need it. So I've gone to every two years. Often they still look good, but I do it anyway on general principles. I have an older, single axle TT without the EZ Lube feature. But regardless, I'd still pack them by hand, my attitude being if it's EZ it's not the best way to do it.
