RV.Net Open Roads Forum: Good quality synthetic rear differential gear oil
 > Good quality synthetic rear differential gear oil
lfeather
Titusville, FL
Posted: 06/23/12 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Captain_Happy wrote:
I wouldn't be using sythesia oil in my rear end after what my mechanic told me about how thin this kind of oil can get when it gets hot. It doesn't stick to the drive shafts long enough to get to the outer wheel bearings. He ought to know, he works on these things.
I disagree with your mechanic's assessment. The low viscosity (thinness)is one major benefit of synthetic oil, allowing it to reach/lubricate all those small spaces that dino oil can't reach, with superior lubrication properties at all temps to include very cold temps. Dino oil breaks down under very hot or overtemp conditions, while synthetic oil still provides protection. Jet engines must use syntetic because dino oil can't withstand the extremely hot temps. I have been running sythetic oils in all my vehicles for over 30 years.
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Towed
SMI Air Force One toad brake
The Texan
Meridian, Idaho
Posted: 06/23/12 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't be using synthetic oil in my rear end after what my mechanic told me about how thin this kind of oil can get when it gets hot. It doesn't stick to the drive shafts long enough to get to the outer wheel bearings. He ought to know, he works on these things.
If my mechanic told me that, it would have been my last visit to his shop. Wrong knowledge, is worse than no knowledge.
I use Lucas synthetic diff oil in my HR, as that is what the factory service center said to use and what they used, at the time.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Wills250psd
walnutcove NC
Posted: 06/23/12 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Lucas, but its not cheap
jimhaz2402
Crossville, TN USA
Posted: 06/23/12 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Ditto and ditto on Mobil Delvac. If you're a member of FCOC, you get a discount on it @ O'Reilly Auto Parts. jim
amxpress
Clayton, NC
Posted: 06/23/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Here's a couple of links to the "over rated" synthetic gear oil that I have used for over 30 years with excellent results (as have millions):
http://www.amsoil.com/storefront/svg.aspx
or
http://www.amsoil.com/storefront/fgr.aspx
As subjective as using synthetic is on this forum, you can't beat it for overall performance when compared to dino oil, whether it's in your engine, differential, or transmission.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
rexabbot
Cumming GA
rvrepairnut wrote:
agesilaus wrote:
Lots of people use Amsoil
one of the worst over rated gears oil of all time
Give details - don't just throw out opinions.
Daveinet
il
Posted: 06/23/12 08:01am Link  |  Quote  |  Print  |  Notify Moderator
First of all, Penzoil is indisputably junk. Do not use it. Their engine oil looses viscosity long before the normal oil change interval, I can only imagine what their gear oil is like. DO not use Lucas either. At higher speeds, their treatment causes the oil to foam up.
Amzoil Severe Gear is pretty good, or Royal Purple Max Gear. I did a bunch of research when I blew my diff last fall. Mostly finding out what off road racers are using. These are guys that tare up differentials in single race. Its not uncommon to rebuild the diff every race. Not too much bias to their opinions, as they operate in survival mode and can't afford to be wrong.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
Weathertodd221
FL
Posted: 06/23/12 08:03am Link  |  Quote  |  Print  |  Notify Moderator
what kinda racers?? Nascar have differential coolers.
Sully2
Cincinnati
Posted: 06/23/12 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Amen brother!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Sully2
Cincinnati
Posted: 06/23/12 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I wouldnt be afraid to use Pennzoil Syn in my coach. I DO use it in my front hubs.
You might also look at Castrol Syn in the proper weight. None of them are cheap by a long shot, so just grit your teeth and bear it. After all its not like you change it every 7000 miles or so.
