RV.Net Open Roads Forum: Tech Issues: Summer Soltise power readings
 > Summer Soltise power readings
MrWizard
Traveling
Posted: 06/22/12 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
technically it was Wed .. two days ago
but i've been busy enjoying the Louisville Rally
so today i turned off the converter ALL day and let the Solar power charge the batteries and run the fridge , the fans, lights, TV etc.. shore power was running the A/C
1872.5 WH total
136.03 amp hrs total
291.9 peak watts
21.17 Peak amps
i know i saw sustained 18+ amps at 4:15 pm
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
mena661
Posted: 06/22/12 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
Nice and we you were all the way over in Kentucky too.
Trojan L16 6V's 740 Amp-hours
Almot
Vancouver BC
Posted: 06/23/12 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Was it 136 AH in or out of the battery? I don't remember, your panel is about 200W?
MrWizard
Traveling
Posted: 06/23/12 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
136 AmpHrs into the system, but there were loads .. fridge, several fans, laptop plugged in, but turned off
I have 505 watts of Solar flat on the roof
Note the peak watts 291.xx
my controller maxes out at 25.xx amps
Almot
Vancouver BC
Posted: 06/23/12 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Loads don't change the panel output. Your peak current was 21A, so 25A controller didn't cut anything off on this day. Just to make sure I've got it right - total 136 AH output from flat 500W panel?
MrWizard
Traveling
Posted: 06/23/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
correct
1875.2 Watt Hrs
136 amphrs
I'm at the Louisville Ky Good Sam Rally, and i've been plugged into shore power for several days
the converter is basically in float mode
and the batteries are sustaining a fairly high charge level
they were NOT low from overnight use
the solar only needed to supply the days consumption, NOT recharge the battery bank of eight batteries 960 ampHrs
i don't get multiple days of shore power very often, we normally dry camp
just before sundown i plugged in my vector 40 amp charger set on AGM, and zap them, then i'll change it to desulfate and let run until we break camp
KendallP
Grants Pass, OR
Posted: 06/23/12 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
That's awesome, Wiz!
Shore power, eh? Sounds like a good opportunity to do some battery conditioning.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
Almot
Vancouver BC
Posted: 06/23/12 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
I thought 500W panel would collect a bit more AH. Around 160-170 AH. Though... If it was hot, and panels not cleaned for a while, and are 7 or 8 years old - this could explain 136 AH.
MrWizard
Traveling
Posted: 06/24/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
yes it. was hot 94F a few scattered clouds high humidity
and the panels are Not new
they were cleaned last week, they had several weeks of Az dust and road dirt on them
mena661
Posted: 06/24/12 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
The VEC will let you do that in AGM mode? Or are you switching to flooded for that?
