RV.Net Open Roads Forum: First time rving Trouble shooting Hydraulic jacks
 > First time rving Trouble shooting Hydraulic jacks
Oceancouple
Posted: 06/23/12 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I left lights on in coach and wasn't hooked up, lost charge to batteries for coach. Had tipouts extended. Hooked power up to coach from outside and moved tipouts in to leave site. Had engine going with brake on and pressed panel to drop jacks, only went up half way and stopped and LCI panel lite up like xmas tree. Before calling in to have serviced any ideas what i might do to correct.
jerseyjim
New Jersey
Posted: 06/23/12 05:36am Link  |  Quote  |  Print  |  Notify Moderator
As far as I know, jacks need the batteries to have, at least, a reasonable charge to operate. You say you let the batteries completely discharge. Might take awhile for them to charge back up.
Mine are hydraulic like yours, and, as far as I know, once you push "retract", the springs do it all.
Your coach is new (2011) so you should have all kinds of owner manuals...one of which SHOULD be from the jack manufacturer. Find it...read it...perhaps the answer is there. ((Mine are from Power Gear, they have a website with "troubleshooting"...check that out)) You still have a warranty? Then take it back to the dealer. New coaches can have alot of "teething" problems. Use whatever warranty you have well.
Whatever you do....g'luck.
garym114
Bluff Dale, Texas
Posted: 06/23/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
The control power for the jacks usually comes from the chassis battery and the operation power comes from the coach batteries.
Charge the coach batteries. It takes a while if they have been completely discharged.
MrWizard
Traveling
Posted: 06/23/12 08:37am Link  |  Quote  |  Print  |  Notify Moderator
the 12v control valves need to open for the springs to retract the jacks/levelers
sounds like voltage dropped to low for the control board to function correctly
shut off everything
disconnect engine battery
reconnect engine battery
start engine wait 10 minutes then try retracting the jacks
if your slides and jacks all use the same hyd system
its a good idea to do only 1 thing at a time
pull each slide in “one at a time"
then retract the jacks
do this with the engine on, or at least with the generator running so that
the batteries are being supplied with power
if your house batteries were near dead, very likely they were taking so much charge from the alternator that it could Not supply the the pump with enough power
the voltage drop caused an overload and shut down
just so you know
they don't make 'tip outs any more even on trailers
you have slide outs
drop jacks would mean Extend them and level coach
so I think you meant 'Retract' them
it can get real confusing , when someone says the opposite of what we think they are trying to say
* This post was edited 06/23/12 08:52am by MrWizard *
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Oceancouple
Posted: 06/23/12 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Thank You all for your responses never thought I would get so many. Also will remember about lingo properly used for rvs Thanks Again
Mike and Trish
Southern Delaware
Posted: 06/23/12 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of jacks have no springs -- neither of my coaches have had them.
Mike and Trish
2008 Mandalay 43A
2008 Jeep Liberty on Blue Ox towbar
Yorkiepoos - Janis and Jimi
00 BUCK
NE Ohio
Posted: 06/23/12 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that the Lippert unit isn't leaking hydralic fluid into the motor .
Mine did that and was - " lighting up the control panel "
They were put out with a bad oil seal and have since changed that design .
I got a new seal , new motor and it has been good since . Check your motor if it has oil sprayed all over it well that is bad news
2011 Newmar - VENTANA -- with COMFORT DRIVE
2011 Jeep Wrangler Unlimited Sahara
Blue Ox Aventa LX Tow bar w/ Roadmaster adapters
AirForce One brake system
Life Member GOOD SAM Club
FMCA Member
If your not the lead dog
the view never changes
