RV.Net Open Roads Forum: Hybrid Travel Trailers: Front bunk gasket
Open Roads Forum  >  Hybrid Travel Trailers
 > Front bunk gasket
B250ramvan
Kansas City, Mo. USA
Posted: 06/23/12 06:11pm Link  |  Print  |  Notify Moderator
Our front bunk door had a leak somewhere,
on our 2003 Trail lite hybrid.
If you had that problem,
what did you do to fix it,
or did you replace the gasket?
SooperDaddy
Posted: 06/23/12 06:33pm Link  |  Print  |  Notify Moderator
It might be better to leave the original seal as it is, and add a 2nd seal all around the 1st one.
You can apply a thin coating of black artists charcoal or red dyed cake frosting
on the existing seal, shut the bunk door, and see where the seal is not making contact with the trailer.
Then you can add additional seals to that area or adjust the "slam latches" to make a tighter seal.
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
bikendan
Camano Island, Wash.
Posted: 06/23/12 07:30pm Link  |  Print  |  Notify Moderator
the best and quickest way to check the whole trailer, is to take to a RV shop that does the Seal Tech leak test.
here's their website with a list of places to have it done:
Seal Tech locations
the shops usually will be able to fix where the leaks are.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
Jerry9n
SE Michigan
Posted: 06/23/12 08:23pm Link  |  Print  |  Notify Moderator
Had trouble with mine when I first got it and the dealer added a second seal. Not sure what yours looks like, but the door has a lip that goes against a D profile gasket. He put a ribbed rubber gasket all the way around. It looks like this in profile:
I found these to be pretty much stock from RV dealers service depts. I've not had trouble with the door seals since.
Regardless I would have a pressure test done. I built my own using a furnace blower and on a 3 year old trailer ended up recaulking the whole trailer. Pay special attention to the running lights, they are notorious for leaking.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
 > Front bunk gasket
