RV.Net Open Roads Forum: Went from Class A to TT...have some issues....
 > Went from Class A to TT...have some issues....
lov-cmping
Massachusetts
Posted: 06/24/12 10:33am Link  |  Quote  |  Print  |  Notify Moderator
misteramx
anaro
I'm not sure who posted the Geo Method, but I can tell you that I started using Calgon Water softener and without using any kind of
wand or hose, my black water gauge is starting to work! Albeit slowly, I think I will get it clean...
2002 30 ft. Springdale, Started out at home and used about half a bottle of the water softener, filled the tank about half way with water and used a good squeeze of dawn dish soap. It had a good 2 hrs to slosh around the first time...
Then we towed for Memorial day weekend, added water, flushed out the tank before leaving and added more of the same. We then drove about 40 minutes to our seasonal place and I can tell you that I have not had the slight toilet smell that we have had for years. Every time we dump the tank I add about half a bottle of the water softener and a bit of dawn and so far I am very happy not having a "slightly stinky" bathroom when we head up to the lake. Whoever posted this method also was correct when they say lots and lots of water...
Even if the exhaust fan is on, and you happen to flush, I don't get the smell I used to. Have not used toilet chemical at all this year.
Calgon Water softener is $5.34 at my Walmart for 1 qt. Give it a try, I would recommend it based on my results... Good luck.
anaro
Mebane, NC
Posted: 06/24/12 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
lov-cmping wrote:
misteramx
anaro
You don't need that much calgon. One capful will do it. We use laundry detergent because it is less sudsy but I am sure either will work. This is the geo method recipe I use. I use the bleach sometimes but not all of the time, I adjusted down the amount of calgon to 1 capful and it has worked well for us. We do still rinse the tank but it rinses to clear coming out pretty quickly.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
6 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
fairfaxjim
Fairfax, CA
Posted: 06/24/12 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
On the AC - does the fan run when you turn on low or hi fan only, or does it only come on when you go to cool?
Usually the fan should run all of the time, and the compressor will cycle on and off. Sounds like crossed up wiring.
Jim & JoAnne
2007 Toyota Tundra Double Cab
2004 Starcraft 11RT (Replaced by)
2011 Eclipse Milan 18CK Travel Trailer
misteramx
Idaho
Posted: 06/27/12 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, thanks for all the great replies. I'm taking it out this weekend for a 3 night jaunt, I'm going to try the water softener first, since I have some in my laundry room. If that doesn't cut it, I'll try that with the ice. Before that, I'll use a want and hose and just clean it out real good. This trailer was parked in an RV park with a constant hook up, so I'm sure that didn't help, the black tank was never moving much.
As for the a/c, it is a single roof unit. Once it kicks on, I have two settings...hi and low fan speeds, as well as auto or on mode. When on auto mode, and set the thermostat, regardless of fan speed, when the temp gets to where it's supposed to be, the fan stops, but the compressor still runs.
As for the range, i'll pull the top and look for a regulator as well as kinked lines, I'm also running a brush and will run air compressor around the exterior of the furnace, try to clean it up a tad...again, this was a full time in an RV park...so it's use wasn't typical, and I'm sure that has much to do with the issues it has had.
Thanks again for all the input, the people and the fun are why I got back into RV'ing to start with and this forum just confirms that!!!
misteramx
Idaho
Posted: 06/30/12 12:47am Link  |  Quote  |  Print  |  Notify Moderator
UPDATE - Did a little research, after lifting the lid to my Magic Chef 4 burner stove, it was determined that it is a 22RA 4Z....and on the right hand side closest to the right front burner is a regulator...no kinked lines that I can find, but I'm going to strongly look at the regulator. However, it aint cheap at $90!! Ouch!
j.p.f.
ga.
Posted: 06/30/12 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
on the stove, if only one burner is on is the flame higher, able to boil water on the one burner?
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 06/30/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Don't even bother with the black tank indicator. I'd estimate that 90% of them, and that's a conservative estimate, don't work correctly. And the other 10% are only accurate part of the time. Just look down the toilet and you can tell if it's full or not.
I've seen some people report here that the exterior type indicators work but I have no experience with those myself.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
