Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
When searching for something such as the OBD port I use my digital camera.
Hold the camera under the dash in different areas and take photos.
Then relax and view them on your computer.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
SoakedKarma
Reno neh-va-duh
Tom N wrote: When searching for something such as the OBD port I use my digital camera.
-Tom
Easier than loosing weight I would say!
set camera on macro and shoot away, good idea!!!
Yellowboat.
Auburn, WA
"All cars manufactured for sale in the US since 1996 have a OBDII diagnostic port as mandated by federal law. This connector is within 3 feet of the steering wheel and must not require tools to access."
"Normally this port is located just under the dashboard above the gas or brake pedal. It can normally be located by simply looking under the dashboard or running your hand along the bottom edge of the dashboard until you "bump" into the connector."
"There are other instances where the connector is behind a cover panel to make its appearance more appealing. In these cases it's necessary to open that panel to gain access to the OBDII port."
On my 2005 Ford V10 the ODB connector is a few inches to the right of the steering Column and had a black snap cover.
JD
2005 Winnebago Sightseer on a 2006 Ford F53 Chassis
Miata on a Featherlite trailer
Mack our Pom
JD & Kathy
driveby
Vancouver BC Canada
and on the iPhone note the EXIF data has your GPS location so we could find you
Glad you got out.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
wny_pat
Western NYS
Ought to be part of the PDI from the dealer. Now everybody remember to ask!!!
OldBlackWater
Keep on rollin'
wny_pat wrote: Ought to be part of the PDI from the dealer. Now everybody remember to ask!!! Where to find the ODBII port, or how to wiggle yourself back out from under there? I swear I felt like a snake trying to slither backwards.
TexasH
Katy, TX
Ford put the OBDII port on the F53 on the right side of the steering column. On mine, I can find it by wedging my hand down the right side of the column between the fiberglass dash to about mid palm. Then it's right by my middle finger. The port has a snap off cover. It is nearly impossible to plug in anything to it and even harder to pull it out. I understand that you can move it by removing a couple of screws and remount it to the Fleetwood dash, but then you'll have to crawl back under there again Why Fleetwood couldn't take the 2 minutes to do that before they covered it is a mystery.
2002 Southwind 37U Ford F53 - V10
2007 Jeep Liberty Toad
OldBlackWater
Keep on rollin'
TexasH wrote: Ford put the OBDII port on the F53 on the right side of the steering column. Is that to the right as you're facing the front of the coach, or as you're lying on the floor with your head wedged into the corner and your face under the parking brake?
pkunk
Questa, NM
Easy now.... it's on the right of the column as your looking forward from the seat. You should be able to touch it with your hand even if you can't see it. Use the camera trick if you can't find it.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
bsinmich
Holland, MI
Personally I don't know how much safer it is to just make a head first drop to the pavement. I try to use my head for other things. Next time you try that why not have someone with a a video camera along. You could get $10K for that on Americas Funniest Videos. Than you could hire the job done.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
