I'm having a bad problem with my computer ,it's very slow.
Most icons do not respond on the desktop,sometimes IE9 works,then not at all.
I'm getting a message not to run Script on this webpage???
What is SCRIPT?...How do I get rid of it?
I did a defrag ,3hours and a disk cleanup,not much help.
Sometimes Windows does not respond.
Computer is a Toshiba,64bit,windows7.
Thanks for all the help.
Siggy
Someone who actually knows what they are talking about will probably give you a good answer.
I am probably as computer illiterate as a person can be and still manage to use one.
BUT I just had the same slooooow computer problem. I ran all of the Norton tuneup stuff and nothing helped. I had to wait long periods just to open old word documents I created.
Then my Yahoo email also would not work, but only on my computer. My Yahoo email worked fine if I used my wife's laptop. So clearly it was my almost 5-year old computer's problem and not Yahoo's.
I went through the Yahoo trouble shooting tips. One of the suggestions was to update and/or change my web browser.
I tried to update internet explorer to version nine. It would not accept the update.
So I changed to Google Chrome, and holy cow, my Yahoo mail started working again. And the overall speed of the computer has improved noticeably.
I figured it was a fluke, so I reset my default browser to internet explorer. Son of a gun, the problem came back.
So if no one gives you credible, knowledgeable advice, then switch your web browser. It can't hurt, and you can always switch back.
"scripts'
are snippets of programing, that tell the page to load certain items or perform certain functions
that "script" is probably trying to access to many servers and load images or ads or something else
sometimes it can happen because the server that the web site/page you want is overloaded ( being used to heavily ) and the data wont transfer fast enough
the script is waiting on some function to complete before doing something else
Options, always have options, and the journey goes much smoother ....
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Just for sh$$$ and grins, have you run a Memory Diagnostics Test?
My 5-yr old Gateway Windows Vista 32 became very slow. Then browsers started crashing. Sometimes back-to-back-back (FF 13.01, IE 9, Chrome last version).
After checking windows vista forum, did the Memory Diag Test and found memory was bad. Replaced the memory with slightly faster version and stability is back with some speed increase, especially boot-up.
It sounds like you're having several problems, possibly related, maybe not. Get someone knowledgable nearby to look at your startup items first. A lot of programs set themselves to load into memory at startup whether they're used frequently or not. This slows down everything else.
You could also have some resident malware that's gone undetected.
Lastly, check for all current updates to the OS and your browser.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox http://happykayakers.com/blogger/
When you first sign into your desktop likely your computer is running too many add on programs "Leach Ware" using up resources. I use Sysinternals Suite Utilities from technet.microsoft.com to control what programs that are allowed to start automatically.
Autoruns for Windows v11.31 Newest Release is the specific utility of the suite showing you what programs are configured to run during system boot-up or log in, and shows you the entries in the order Windows processes them.
If its FREE it's for Me!
JavaScript is THE scripting language of the Web. Sounds like your anti-virus or IE script protection is sending you a warning. Scripts can contain malicious computer code and likely 99% of the warnings are in error it's the 1% that bite you in the arse...
TURN OFF ALL Automatic Updating...
all those programs that load in the background check to see if they are the latest version along with the active programs you are running can bring many a computer to a halt..
AdobeAAMUpdater-1.0
Logitech Download Assistant
Acrobat Assistant 8.0
Adobe Acrobat Speed Launcher
Adobe ARM Adobe Reader and Acrobat Manager
AdobeCS5ServiceManager Adobe CS5 Service Manager
Corel File Shell Monitor
SunJavaUpdateSched Java(TM) Update Scheduler
SwitchBoard SwitchBoard Server (32 bit)
Microsoft Windows Windows Mail
Corel Photo Downloader
AdobeAAMUpdater-1.0 Adobe Updater Startup Utility
very short list of programs removed from running automatically on my machine.
Microsoft Indexing can also slow things down.
Run task manager and check what and how many processes are running in the background.. 67 in my case lots of extra stuff running
so before you think you have a virus or something check to see what extra baggage you can throw overboard first...
Are you running Norton? Norton has a built in speed killer
hershey - albuquerque, nm Someday Finally Got Here
Superman was an illegal alien.
siggdy ---- I am a very heavy computer user. With Windows computers the way they are designed over time they just build up crud. Basically your registry gets big and so even fast ones slow way down. Using the standard disk cleanup and defrag that comes with Windows really help.
You likely have something else slowing your box down. I personally like Advanced Systems Care for cleaning out crub and trimming the registry. It is free. Give that a try.
Even with all the care I give my Windows computer after two years my expensive Sony laptop takes a long time to start up and run right. At least 5-7 minutes. So I just leave it on most of the time. I engage hibernate when I am not using it.
The "final solution" is to reinstall a clean windows OS. Many heavy users do that every six months. Our local computer shop charges 100 bucks. That cleans everything off and you start fresh. But you need to save copies of all your files you want to save.
If you are brave you can download a copy of Linux and load it on your computer. It is free and works quite well. You need to save copies of your files before you do this though.
