RV.Net Open Roads Forum: Class A Motorhomes: GPS in Alaska
 > GPS in Alaska
yudamann
Outer Banks NC
Posted: 06/24/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Will most GPS devices work in Alaska or are you too far north?
yudamann
Outer Banks NC
2005 Allegro Bus 38TGP
2004 Acura MDX toad
Brakemaster toad brakes
"We need more fools to test fool-proof equipment"
wolfe10
Posted: 06/24/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Works just fine-- at least it was very accurate cruising up inside passage.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
steveownby
Cosby, TN
Posted: 06/24/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, they work fine. When I went in '08, I had an old Lowrance and it worked as far as Coldfoot, which was as far north as we went.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
2gypsies
Enjoying the West!
Posted: 06/24/12 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
They work but if you're worrying about getting lost in Alaska, relax...there are very few roads.
Extremely Happy Full-Timers for 16 years
.... now trying to adjust to 3-season traveling - and it isn't easy!
2004 40' Newmar Dutch Star Diesel Pusher
2004 Jeep Liberty
dbbls
Missouri
Posted: 06/24/12 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I was there last summer and it worked most of the time. On some locations I think I must have been behind a mountain because it would loose the signal part of the time. Like 2gypsies said, there are very few roads so you will not get lost.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Livies Dad
Indian Trail, NC
Posted: 06/24/12 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Was just there 2 wks ago and gps worked everywhere.
wa_desert_rat
Central Washington State
Posted: 06/24/12 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
GPS signals can be disrupted by solar flares but usually the error is many thousands of miles and easily recognized. Unless you're flying an airplane it's probably not going to be an issue for you.
Craig
RCMAN46
NorthWest
Posted: 06/24/12 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just got back and my Garmin worked just fine. As for getting lost on their few roads only applies if you stay on paved roads. If you travel the dirt roads all bets are off. There are many of them that can get you in deep trouble if you are not careful.
msmith1199
Central, CA
Posted: 06/24/12 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
The GPS satelites are in a medium earth orbit meaning they don't stay in the same place in the sky like the Directtv and Dish Network satelites do. The ones that stay in the same place are in a geosynchronous orbit directly over the equator. So when you get too far North or South your reception from those satelites are affected. The GPS satelites run at an angle to the equator so you get coverage at both the north and south pole.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
SCVJeff
Santa Clarita, CA.
Posted: 06/24/12 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned above, the GPS Constellation is not geosynchronous. It looks like this, so it makes no difference where on the planet you are.
Jeff - WA6EQU
 > GPS in Alaska
