RV.Net Open Roads Forum: Class A Motorhomes: Generator only runs when engine running
 > Generator only runs when engine running
kidgold
Lakeside, CA, USA
Posted: 06/24/12 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I recently replaced my engine batteries in my Allegro and now the generator only runs when the engine is running. As soon as I turn the engine off, the generator stops immediately. Sounds like someting electrical. Any suggestions?
Thanks.............Richard
"River or Desert??...To ski or sand is the only question"
Crazy Ray
Monroe,La
Posted: 06/24/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Richard, What brand/make Genny would HELP don't you think. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
dalmationlovers
Port Orchard, WA
Posted: 06/24/12 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the connection between the generator and your batteries. I have a lead that runs from my generator directly into the batteries bay. Just a thought.
Arnold
othertonka
Stockton, CA
Posted: 06/24/12 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
The generator usually starts from the "House" battery, not the chassis battery. Is the house battery dead or weak or is it fully charged? I am guessing that it is weak and by having the engine running the alternator is charging it enough so you can start the gen set. When you shut the engine off the alternator quits charging and there is not enough voltage in the house battery to keep it running. Or as a second thought, do you have the battery disconnect switch for the house battery in the OFF position? If so turn it back on. Use a volt meter to check the voltage on you house battery and go from there
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
kidgold
Lakeside, CA, USA
Posted: 06/24/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Both of the batteries are fully charged. But, when I hit the Aux Start Button on the dash (a momentary switch that sends power from the house batteries to the chassis batteries), it works fine, until I let the aux start button go at which time the generator promptly dies. I should also note that the engine doesn't have to be running, just the key in the on position (ready too start). This is really wierd.
garym114
Bluff Dale, Texas
Posted: 06/24/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
For some reason the coach battery connection is not getting to the generator.
kidgold
Lakeside, CA, USA
Posted: 06/24/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I found it. It was a 250A fusable link between the chassis & house batteries.
