RV.Net Open Roads Forum: Tow Vehicles: Tire Pressure for Dodge Ram 350 Diesel?
Search only in Tow Vehicles
 > Tire Pressure for Dodge Ram 350 Diesel?
tom855
Maryland
Posted: 06/24/12 09:29pm Link  |  Print  |  Notify Moderator
I just picked up a Dodge Ram 350 Diesel to pull my 33' 7500# TT. My question is about truck tire pressure. Tires are 265/70R17 "E"s, and the door panel says inflate based on load. It says:
Minimal Load, 50F/40R
Max Load, 60F/75R
So that's easy with the truck alone, but what about with a TT with the tongue weight and the load distribution bars that push weight the front end? I have no idea if where in that inflation range I should be.
Any recommendations on how to best inflate the truck tires when towing?
Thank you!
Tom
brirene
midwest
Posted: 06/24/12 09:41pm Link  |  Print  |  Notify Moderator
I would go with the maximum figure. JMHO.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Greentreena
British Columbia
Posted: 06/24/12 09:55pm Link  |  Print  |  Notify Moderator
Try the max presure, then tow, at your first fuel stop, check the tires and if you have a dark line on the outer edge on the tire tread, deflate 5 psi and check on you next fuel stop. You don't want a dark line on the outside edge of the tire tread. If you aren't sure what I mean. Inflate the rear tires to max and go for a drive without a trailer, you will see the dark line on the tread that will be about 1/2" to 3/4" wide.
I run 60 psi in the front and 65 in the rear with my current E range tires when towing.
Hope that helps.
2008 Dodge Ram 3500 6.7 Mega Cab 4x4 SRW Laramie - Big & Black
Full delete, Torque Technolgies programmer, Sinister EGR delete
Hijacker Auto Slide/ P3
2006 Triple E Topaz 310RBXL
Wife, 2 kids (Murphy the dog - RIP friend)
seattlefirervr
Snohomish, WA
Posted: 06/24/12 10:18pm Link  |  Print  |  Notify Moderator
I would at least start with 5 PSI under Max reccomendation. This will allow wiggle room for heat and/or elevation changes. Like previous posts allude to, take a visual on tire wear after travel and adjust as needed.
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
hmknightnc
Wilmington, NC
Posted: 06/24/12 10:31pm Link  |  Print  |  Notify Moderator
I run 65# on all tires of my dually based on the max load recommendation on the door pillar. The tires are E rated with max pressure allowed by sidewall of 80#
Old-Biscuit
Verde Valley
Posted: 06/24/12 11:42pm Link  |  Print  |  Notify Moderator
I run 65# front & 80# rear (MAX PSI/LOAD) on my Dodge Ram 3500
but I'm towing a 5'vr.
Put 65# in front & 75# in rear......hook up trailer and then go get it weighed so you know what axle/tongue weights you are dealing with. You will also know what the trailer axle weight is.....then you can inflate the trailer tires to correct pressure/load.
When not towing drop pressures on RAM 3500 to 50# F & 40# R.....that CTD is heavy.
SoCalDesertRider
Arizona desert
Posted: 06/24/12 11:47pm Link  |  Print  |  Notify Moderator
When loaded, 65 psi up front and 80 psi in the rear works good with 80 psi single tires.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
eHoefler
ozark mountains
Posted: 06/25/12 05:35am Link  |  Print  |  Notify Moderator
In all my Ram duallys, I have run 80 psi up front regardless of load, 80 psi in the rear pulling the fifthwheel, 45 psi in the rear when not pulling the fifthwheel. Rotate every 7,500 miles, and get very even wear.
2014 Ram Laramie, 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 06/25/12 10:09am Link  |  Print  |  Notify Moderator
Is it a 350 or 3500 dually??
Is it a 3500 single rear wheel?
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
45Ricochet
North Idaho
Posted: 06/25/12 10:20am Link  |  Print  |  Notify Moderator
Sidney
265/70R17 is pretty fat for a dually [emoticon]
Here is a tire weight rating table. I believe all tire manufactures have one. If you know your exact loaded weights you can look up the proper PSI. SRW your most likely looking at full 80 psi rear, 65 front.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
