SCVJeff
Santa Clarita, CA.
fordsooperdooty wrote: Verily I say unto you...tho you be cast into the fires of Hell....and the smell of brimstone is all about, Get thee to a Home Depot...and get ye some mylar foil bubble wrap insulation...cut it to size and thoust will be cooler...for little pence out of yer pockets. That's the Gospel as written by Fordsooperdooty!
(Chapter 5, verses 1 thru 4)
Having a cold glass of beer wouldn't hurt either! So Jesus was from the South was he?
Jeff - WA6EQU
DFH-GMC
Pull the air diffusers and check the seal to the ductwork. When I got my KZ it had a large gap and was mostly cooling the gap between the roof and ceiling.
03 GMC Sierra
07 KZ 2505QSS-F
Almot
Vancouver BC
Reflecting film, albeit not the most efficient thermal barrier, is the only thing that will provide some insulation without blocking the light.
sunkatcher
Fulltimer
Place any thing on the inside of your windows is a great way to bust the seal and have foggy windows. Place your material on the outside and stop the heat BEFORE it gets inside.
Ron
masa4u.com
dupreet
High Point, NC
The Reflectix works great in knocking down some heat. Another potential help would be a reflective elastometric roof coating. I spread a 5-gallon bucket of Henry's 287 on my TT roof last month. Ithas made a big difference in keeping the trailer cooler, and is an added protection from leaks!
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
c3saving
East Coast
We used to have a popup. A popular mod was to put something called popup gizmos on the bunk ends and reflectix inserts in the window panels. It definitely worked. I made some bunk end covers out of spaces blankets by Cabellas. I wonder if you temporarily affixed a space blanket to the roof, if you would see a difference. The blanket has grommets on it. I'm thinking suction cup hooks to hold it on. Just make sure to not cover the a/c unit. A cheap temporary option.
NuttyTexans
Livingston, Tx
Our solution, when we only had one q/c unit, was foil on the windows, cover or plug the crank up overhead windows and several fans. Moving the air helped us BUT there was a point around 101 or so when nothing came out of the a/c but warm air. At that point we headed to the mall, or somewhere, till it cooled down some. Feel your pain since we lived in Sherman at the time.
sjholt
Henderson, NV
I've been using Reflectix for years. I have it cut to size for every window and put it between the window and the blinds. If it helps in the Las Vegas area- it will help you.
I also used it in November in Pa. using one heat strip, I was able to survive.
I hate cold weather.
I know it can be bought cheaper, but Camping World had a 4 ft size that fit my windshield with minimum cutting.
HTH
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
TomG2
Central Illinois
Surprised that no one has mentioned cutting your loss of cool air by placing magnetic covers over floor vents. Another trick that I use is to turn a sprinkler on that dampens the top of the trailer. Doesn't have to be on constantly, the evaporating water really pulls the heat off the roof and keeps it out of the trailer.
Jay Pat
Round Rock, TX
seattlefirervr wrote: fordsooperdooty wrote: Verily I say unto you...tho you be cast into the fires of Hell....and the smell of brimstone is all about, Get thee to a Home Depot...and get ye some mylar foil bubble wrap insulation...cut it to size and thoust will be cooler...for little pence out of yer pockets. That's the Gospel as written by Fordsooperdooty!
I read your post twice and I am still laughing during this reply! If this forum had a Hall of Fame, your post would be a nominee! That being said, your post was informative and I am going to buy a roll of that stuff myself! Two ice blocks and a case of beer too!
I have a sets of this material for the inside of windows (traveling down road and stationary) and another set for when parked.
The stationary set velcro over outside windows and the frames. The frames transfer heat as well.
Windows are 4' radius and door windows are 2" radius.
Pat
2010 Ford F-350 SRW
2011 Keystone, Sprinter 310
