RV.Net Open Roads Forum: AC Not Keeping Up - Would Tin Foil On Windows Help?
 > AC Not Keeping Up - Would Tin Foil On Windows Help?
pianotuna
Regina, SK, Canada
Posted: 06/25/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Hi Jay,
What does this mean? Sorry I can't understand it.
Jay Pat wrote:
Windows are 4' radius and door windows are 2" radius.
Pat
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Dick_B
Palos Heights, IL USA
Posted: 06/25/12 06:35am Link  |  Quote  |  Print  |  Notify Moderator
I take it the windows are not tinted. If they are there is a possibility of overheating them if the foil is placed inside the windows. This has been discussed previously; I think on this Forum
Also, get a decent size, QUIET circulating fan to help move the air around.
X2 to leave the A/C on all day/night so it doesn't have to cool all the furniture, walls, etc. every time it is turned on.
If things continue bad after all of the good suggestions get a Sunshield tarp and throw it over the roof with silver side up and with cutouts for the vents and A/C. It will reflect the sun and the space between it and the roof will act as additional insulation.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
wingtraveler
Alamo, Texas
Posted: 06/25/12 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
There is a point to this topic that sunkatcher was pointing to but did not explain 100%. IF you have single pane windows, placing reflective foil or anything else is a way to go.
If you have double pane/insulated windows, you are REALLY taking chances of overheating the seals and the end result is fogged windows. I allowed my wife to talk me into the MCD shades with the sunscreen on the inside. Mind you they are not tight against the windows. I had windows in the direct sun in Tallahassee and with the sun shades down the temperature of the window and frames was 145 degrees F.
I went to Lowes and purchased sunscreen material then made OUTSIDE covers for the windows in the sun. The temps dropped to 85 degrees within minutes. I HATE THE OUTSIDE COVERS but they do shield the insulated windows from the direct sun.
If you were to call the manufacturers of the insulated windows in your home you will find most advise against films etc. They will void the warranty.
If of course you have single pane windows you can do anything you want. Hope this clarifies a bit more.
08 Discovery 40x
08 Hyundai Sonata GL toad
08 Honda Goldwing
nitrohorse
pa
Posted: 06/25/12 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Time to sit in the 100 quart Marine Igloo cooler with the plastic wheels and have the wife take you for a refreshing ride through the campground.
