RV.Net Open Roads Forum: Beginning RVing: Confused about fridge
 > Confused about fridge
chimeraxp
calgary
Posted: 06/24/12 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a bit confused with my fridge ,
in the access panel behind the fridge it has a switch that says 12v or 120v
when I open the fridge it has a propane tag .
but the stove top is located right above the fridge as well is the tag for the stove top ? or the fridge propane .
I have yet to hook any batteries/ gas yet . I want to know whats what before I start down that path .
The TT is a triple E about 1980.
I would post pictures of that fridge but can't get any to load right.
Johnworth914
USA!
Posted: 06/25/12 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Without seeing it, I would say a TT of that vintage would have had a 2 way fridge--propane and 120V
The 12 V is for the control board. Even when using propane, you need to have 12V to keep the fridge running.
There are 3way fridges as well that operate on your choice of 12v, 120V or Propane. Make and model of the fridge would be helpful to determine what you have.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
beemerphile1
I'm 57, I'm not a
Posted: 06/25/12 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have a three-way refrigerator like in pop ups. I don't know what you mean by "propane tag". Normally all the controls are in the back of a three-way refrigerator.
A three-way refrigerator can only operate on one source at a time and should only be operated on 12v while towing. 12v operation will kill a battery quickly if it isn't powered by the alternator of the tow vehicle.
- Soren Kierkegaard
sparkydave
Macedonia, OH
Posted: 06/25/12 07:16am Link  |  Quote  |  Print  |  Notify Moderator
In a 1980 refrigerator? Don't be too sure. I have a 2004 camper, but my 3-way Dometic refrigerator has no control board in it. Just two switches for 12 volt and 120 volt, a thermostat for the 120 volt operation, a gas valve, and a spark ignitor. Does not need 12 volts to run a control board since it has no smarts in it.
skipnchar
Topeka or somewhere else
Posted: 06/25/12 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Try it on all three and see how it does. It SOUNDS like a three way fridge (usually very small in size) and the 12 volt option is more of a "holding" feature. Usually doesn't do much at COOLING the fridge but will keep it cool once cooled on other modes. They still make that type of fridge, usually for truck campers, but they are becoming more rare.
Terryallan
Foothills NC
Posted: 06/25/12 09:19am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned. It is a 3 way. It will work off propane, You need to physically light it. It will run off 120. You need to flip the switch to 120. It will run off battery. Just not long, unless your TV is hooked up in such a way to provide 12V to it.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
chimeraxp
calgary
Posted: 06/25/12 09:31am Link  |  Quote  |  Print  |  Notify Moderator
ok sounds greats , one day i'll figure out how to post pictures .
but off to work now.
JLTN_James
Colorado
Posted: 06/25/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
This is what my 3-way fridge controls look like.
The dial on the left if for the propane and has OFF-HIGH-MED-LOW settings. To light, I set it on the HIGH setting while pushing the dial down to bypass the flame detection safety, then press the red ignitor button just like a BBQ grill at home.
The green rocker switch is for 120Vac operation. The right hand dial adjusts the temperature when in 120Vac setting.
The red rocker switch is for 12Vdc operation. No temperature controls when in 12Vdc operation.
As previously noted, running the fridge on 12Vdc will drain a battery pretty quick. Depending upon the charge line from the tow vehicle, it may even draw on the batter when on the road. I avoid 12Vdc operation like the plague.
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, Dog & Camping Kitty
chimeraxp
calgary
Posted: 06/25/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Went out to the trailer tonight when I got home .
took a really good look at the back side , and low and behold there was a plate with oodles of dirt once I cleaned it all off , it was the lighting instructions .
once I have a few moments to spare I can upload pictures to my Photobucket and go from there , encase any other Canadians pop on here with an older Triple E trailer.
but it does tell me to switch voltage to off before lighting so this leads me to think no 12v needed.
Wherever I happen to park
Posted: 06/26/12 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
You have a single switch, 2 position (or is it 3) that says 12v 120v
There is such a thing as a 3-way Fridge.. Runs on 12v, 120v or propane.
If that is a 3 position switch, center is likely propane
If it's two, then a switch elsewhere choses Electric or gas, and that one chooses which electric system (12 or 120) leave it in the 120 spot.
