RV.Net Open Roads Forum: Fifth-Wheels: Mice....still
 > Mice....still
Nalphins@charter.net
Michigan
Posted: 06/25/12 11:44am Link  |  Print  |  Notify Moderator
I have a mouse or something living in the walls of fifth wheel. I set two traps but I am wondering if it is stuck in walls and can't get out. I see where it trys to get out by headboard and by tv from shavings of some sort. Any ideas? Thanks!
troll3193
SouthWest, MI USA
Posted: 06/25/12 11:50am Link  |  Print  |  Notify Moderator
I just de-moused ours this weekend. First time we have had mice in 8 years of owning it..
I figured out that my floor is a sandwich, it has two layers of plywood with insulation and about a 2 in gap between the sheets.
They were able to get from place to place via this passage.
I found they were making their home in the floor heating duct and I used the leaf blower to clear the ducts. I wish I had a video of me blowing the remaining mouse out of the camper.
I left a pair of baited traps in, but I believe I finally got them all and also closed up where they got in.
Good luck,
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
JoeWebPage
Palisade, Colorado
Posted: 06/25/12 11:55am Link  |  Print  |  Notify Moderator
Good luck,
Bryan
ROTFL ... Yeah that would have been a video gone viral in no time!
2012 Durango 2500 325RL, Remote jacks, 5500 Onan, TST TPMS
2004 GMC Duramax, USAF retired ">
troll3193
SouthWest, MI USA
Posted: 06/25/12 01:43pm Link  |  Print  |  Notify Moderator
I am sure. I found that they had been in the heating duct, which runs in the floor, has four floor registers and a ducted port in the bunk room.
They had eaten a whole in the plastic cover for the ducted port.
I pulled off all the covers and started by blowing from the outside at the heater housing.
When I got inside, I blew into the ducted port first and nest material started coming up the four floor registers.. I hit the gas and all of a sudden up popped the last mouse..
I gave chase around the camper till he went back down a duct and I couldn't get him out. Took a few minutes break and went at it and popped him out again and eventually blew him out the camper door..
I first noticed the mice in January, and between then and now had killed 4 of them with normal traps. I knew I had one more for sure.
I think I got them all now, and fortunately they didn't cause any real damage... BTW, I hand cranked the electric jack and hand cranked the slide out, so I could fully inspect before putting AC or DC power to the TT..
Bryan
midnightsadie
ohio
Posted: 06/25/12 02:13pm Link  |  Print  |  Notify Moderator
stop at a feed mill buy a product call kab clean. the farmers use this in there $300.k tractors to keep rodents out.
troll3193
SouthWest, MI USA
Posted: 06/25/12 02:28pm Link  |  Print  |  Notify Moderator
do you have a website for that product? is it a chemical, or a device... google has failed me :-)
maniac007
South Carolina
Posted: 06/25/12 03:32pm Link  |  Print  |  Notify Moderator
Here is the web site clicky. It is called Fresh Cab and you can get it through Ebay or Amazon.
02 F350SD 7.3 CC 4X4 DRW, 06 Cougar 314EFS Eastern Edition
cabanaman
florida
Posted: 06/25/12 03:39pm Link  |  Print  |  Notify Moderator
Had 1 mouse all over and in the walls,heard him in the pot and pan cabinet so set a trap there and got him in just over an hour.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake. Emissions removed.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
john&bet
North Vernon,in.
Posted: 06/26/12 08:04am Link  |  Print  |  Notify Moderator
We were just discussing this very subject this weekend at our chapter campout. The majority of the folks said dryer sheets work very well. Just put them in several places around the rig. I am headed out in a bit to put some out to see if I can get prevent them in mine. Good luck.
2004.5 Dodge 2500ctd Quadcab. Lariamie, 3.73, auto. pure stock
2018 Grand Design 337RLS
Jersey Shore
Jersey Shore
Posted: 06/26/12 10:01pm Link  |  Print  |  Notify Moderator
DP
'06 Ford F-350 6.0 CC LB SRW
'04 Holiday Rambler 37CK Toy Hauler
 > Mice....still
