dtzackus
Cumbola, PA
This past weekend, I backed into the site and noticed the site wasn't level front and back, a moderate grade. Parked it where I wanted it, prefectly level left to right, but the back to front was way off. Luckily, I had a few 2x6's and 1x6's to put underneath, I even added some plastic lynx blocks to help out. The hitch was a good 2 feet off the ground. I dropped the jacks on all four sides, but I still got a little wobble inside the camper when the kids were walking around.
Any suggestions or recommendations I could of done differently? Thanks in advance...
Dan, Tammy, Cory, Leah and Adam
2011 Chevy Silverado 2500HD 6.0
2012 Conquest 297DBS
Equal-i-zer Hitch
GM Integrated Trailer Brake Controller
skipnchar
Topeka or somewhere else
two feet off the ground would not be very extreme on my trailer at least. There is a good chance your movement was due to having the stab jacks at the corners which allows the suspension to still bounce due to frame flex. Adding a third set of stabs amidships is easy, inexpensive and pretty effective in preventing suspension bounce. You can even try it out with just a couple of jack stands before investing in the set of stabs.
Good luck / Skip
dtzackus
Cumbola, PA
Skip, where would I put a third set???
Bill & Kate
Stone Harbor, NJ
Running the wheels on the front axle up onto a couple of 2-bys might help out a bit, plus more blocks under the front stabilizers - the less the stabilizer are extended, the sturdier they are
Bill & Kate - Stone Harbor, NJ
w/ Sunny (parti poodle) & Molson (goldendoodle)
2005 Ford/Quigley 4x4 E-350 Chateau Super Duty Van with 6.0L PSD ("Moby")
2012 Outback Super Light 277RL - 10th Anniversary Edition ("Salty Dog House II")
old guy
Oregon (pronounced Or e gun)
I take it you could not move back into the site further and cut down on the height of the tongue. I get nervous when my TT tongue is that high
KD4UPL
Swoope, VA
2' in the air doesn't seem that high. I wouldn't worry about it.
dtzackus
Cumbola, PA
My wife was just "scared" that we would fall off the blocks and wreck the camper... Plus I was a little annoyed with the boucy feel when the kids were walking around. O well.
Verne
Carson City, Nevada
We boondock in the "outback" and often have the hitch at least that high. In addition to blocks of wood to support the jack, I also carry two 8"-4x4s and two 8"-8x8 blocks for under the front, or rear stabilizers as needed. I agree with "cathcartww" in that the less the stabilizers have to be extended the better.
-Verne, Brenda and
Latté, a Welsh Corgi
Carson City, Nevada
2010 Tundra 5.7L
2010 Jayco JayflightG-2 23FB
eu2000i Honda generator and Companion
Equalizer WD System
Dick_B
Palos Heights, IL USA
Trailer movement has been discussed on this Forum. Look onto JT's Strongarm Stabilizers.
They help but on anything other than a concrete pad there will be movement between the corner stabilizers (not jacks) and the ground.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
beemerphile1
I'm 57, I'm not a
Two feet is nothing.
For more stability put blocks under the stab jacks. They allow more movement the further they are extended.
- Soren Kierkegaard
