RV.Net Open Roads Forum: Tech Issues: Broken Bathroom Door Lock
 > Broken Bathroom Door Lock
SweetLou
La Quinta, CA USA
Posted: 06/25/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
My cheap bathroom door lock broke. I need to replace it although I don't know if I can use a standard home lock. I don't need a lock for the door, just new door knobs. Can I do this?
2005 3500 Cummins HO Quadcab 4x2 3.73 6 spd man, 2007 HitchHiker Discover America 329 RSB
We love our Westie
ch-ta
MN
Posted: 06/25/12 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem on my old TT. I was able to pick up a new handle at Ace Hardware that fit. It was also a much better quality handle.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
J-mans Dad
SF Bay Area
Posted: 06/25/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Just replaced both the bathroom door and the bunkhouse door locksets after the knob(s) fell off. Home Depot Kwikset passage locksets were direct replacement for mine. Didn't need to remove the latch assembly, just the knobs. About 2 minutes to replace everything.
The Car Doctor
Utah
Posted: 06/25/12 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
I used a regular household knob when mine broke. I had to modify the hole in the door a little, but it turned out just fine.
1989 Ford F250 7.5L 4X4
2004 Nomad North Trail 2560
1981 17' Seaswirl 120HP OMC
sirdrakejr
Las Vegas, Nevada
Posted: 06/26/12 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
Dick_B
Palos Heights, IL USA
Posted: 06/26/12 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Do you really need to lock the bathroom door? We took the lock off the bathroom door in our stick house. That avoided those nasty situations when someone locked themselves in the bathroom accidentally.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
SweetLou
La Quinta, CA USA
Posted: 06/26/12 06:49am Link  |  Quote  |  Print  |  Notify Moderator
No don't want one. We bought one from Wally Mart and it now needs modification. I didn't want to do that so I was hoping for some alternatives.
KA4EBU
memphis,tn,usa
Posted: 06/26/12 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Most residential locksets are for a 1 3/8 - 1 3/4 inch thick door..They also come in 2 common backsets 2 3/8 or 2 3/4 inch - this is the measurement from the edge of the door to the center of the lock hole, some have an adjustable latch for both backsets..Most are for a 2 1/8 inch diameter bore - hole in the door for the lock body..
Don and Pauletta
2003 Phaeton 40RH
2008 Jeep Liberty Limited 4x4
2005 FLHTUCI
Misty - a spoiled Maltese
LadyRVer
Posted: 06/26/12 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Same problem with our bathroom lock. I bought one from Wallyworld and used parts from the old lock and the new lock. Very little modification. Works great. No lock ever again on the br door!
mlts22
Austin, Texas
Posted: 06/26/12 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Passage locksets are on mine. I also added a door stopper so when it is open all the way (I leave the door open unless the TT is hitched or the bathroom is in use so air can circulate.), the doorknob will not make a hole in the wall.
