RV.Net Open Roads Forum: Toy Haulers: to LED or not to LED
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > to LED or not to LED
smkettner
Posted: 06/26/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Interior LED lamps will have the effect of doubling your battery size.
675 watts solar
MaxspeedGSX1300R
NY
Posted: 06/26/12 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
LED tail lights are the way to go for sure! Im going to look into some for inside lighting.
2003 International 8500 with HT530 diesel and 10 speed standard, 2006 38' Coachman Adrenaline fifth wheel toy hauler, 2000 Suzuki Hayabusa GSX1300R, 2008 Suzuki B-King, 2008 Suzuki Bandit 1250S
Take it to the limit!
Mr. Sandman
Corona, CA
Posted: 06/26/12 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
MaxspeedGSX1300R wrote:
LED tail lights are the way to go for sure! I'm going to look into some for inside lighting.
Tail lights inside the unit look cool and work great if you're developing your own film but they put off way too much of a red glow in my opinion.
Tow Vehicle - 2004 Ford F350 PSD 4x4
Hauler - 2006 Weekend Warrior LE3505
Toys - 2009 Polaris RZR LE, 1985 ATC 250R,
2006 Raptor 350, 2008 Raptor 250
2003 Raptor 80, 1999 Yamaha PW50
Billieg2
Gone from this forum
Posted: 06/26/12 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
For one, the electric saved is worth the price. Second, the heat given off is well worth it. My plastic lenses started melting with the reg. bulbs. You can get good cheap bulbs off Ebay from China (where they all are made) just make sure they have the amount of light you need and are the right color. I replace all 48 of my bulbs with LED's and it makes a big difference. I use the 36 led bulbs that are warm white. You can leave them on for days before your battery drains.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
dav5942
Stuart, FL
Posted: 06/27/12 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Power consumption and heat are minimal reasons and not worth the change-however they sure are a lot brighter(makes the DW really happy) if you get the right ones.
2007 Newmar 42' Mid Engine w/Fatboy,Grizzly 550s-in Garage,Rubicon w/4" lift,MotorMetal whls,MickeyT Baja tires-Cherokee w/4"lift in tow, Hog Valley FL(a diamond in the rough)
2010 Part2
Alaska Fishing Newmar Mid Engine 2010 Sportfishing
mowdoc
Las Vegas!!
Posted: 06/27/12 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
One more componet that benifits from LEDs is the 12 volt converter. They take a big load off this expensive item any time you have a light on (12V).
Quality LEDs are not cheap. I am slowly changing my entire hauler over and it will run a little over $800 before I finish - OUCH!!!
Start with the lights you use most. This will gain the most savings. Then as you have the money and time, change the others. You may find, as I have, there are a couple lights you want to keep as they are but most of them will be changed over.
2012 Fusion FZ310 Monster Edition
G614s all tires
2012 F450 Ultimate Lariat
DuraFlap flaps all 4 corners
60 gal aux fuel tank
Reese 18K 5th wheel
BedRug liner
pianotuna
Regina, SK, Canada
Posted: 06/27/12 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Hi mowdoc,
It is unnecessary to pay huge prices for led's. The ebay ones referenced earlier in the thread are just fine.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
derwud
Pasadena, CA
Posted: 06/27/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi mowdoc,
Been there done that.. You get what you pay for... I tried all the e-bay bulbs a few years ago, after they all failed, and one even tried to burn my trailer down. I switched to Rigid Industries LED's and have not had any issues! Scr3w E-Bay cheapies!!
2005 Nissan Titan CC SE 4x4, 2006 Weekend Warrior FS2300
2 Quads, 2 Motorcycle and a '06 Rhino
1 Patient Wife, 1 Crazy child, 1 sweet baby.
RIP Bubba and Toby, we love you.
pianotuna
Regina, SK, Canada
Posted: 06/27/12 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hi derwud,
By all means take care of which bulbs you buy. I was an early adopter and quickly found I needed to have units with a wide range of voltage acceptance. At that time I was paying $27.00 per bulb on Ebay (including shipping, which the seller WOULD NOT combine) which was about a 33% savings over his "stand alone store" where he would combine shipping. Those are now available for reasonable prices on Ebay. The Rigid Industries are most probably made in China and marked up 500%. I do agree they work well, but I don't think spending $800 to relamp an RV is a good or wise use of funds.
Madhatter1
Madeira Beach FL
Posted: 06/27/12 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Are you serious?? Those are the number one reasons to spend the $ and change them all out. Did my boat 2 months ago and the camper is next.
