RV.Net Open Roads Forum: Travel Trailers: Axle alignment
 > Axle alignment
CND SuperCrew
SK, Canada
Posted: 06/26/12 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Last year on our return leg from the OR coast, I had to swap out the driver side rear tire because it had worn the inside tread bald. This morning I took the TT to a local frame shop to get the axles aligned. Will report back the finding later today.
* This post was edited 06/26/12 11:55am by CND SuperCrew *
Ron, Lori and Autumn
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2008 Jayflight G2 23FB/ Equal-i-zer WD
2013 Colorado bound
2012- 4000km, 28 nights for the season
2011- OR & CA done, 6800km in 3 weeks
CND SuperCrew
SK, Canada
Posted: 06/26/12 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Tire photos:
SWD
Land of Living Skies
Posted: 06/26/12 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Yuup! Looks like an axle alignment is due! Had this happen to mine many years ago.
Happens lots on those SK roads!!!!!!!
CND SuperCrew
SK, Canada
Posted: 06/26/12 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Readings:
goducks10
Keizer OR
Posted: 06/26/12 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Looks exactly like what I had. Alignment was $190.00 for both axles. The alignment tech said the axles were kinda soft? So he put a little extra camber in.
SWD
Posted: 06/26/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like you got it fixed now!
SilnJohn
Denver
Posted: 06/26/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Curious what did it cost? I was just quoted 145 per axle
2012 Toyota Tundra Crew max 5.7 Limited
2005 F150 Lariat 4x 5.4L, 3.73 (80K mi 4sale cheap needs.......work)
2003 Nissan Pathfinder
2012 Shadow Cruiser 260BHS
CND SuperCrew
SK, Canada
Posted: 06/26/12 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
$110/axle plus local tax. Only shop in our city capable of doing the work.
stevemorris
ontario
Posted: 06/26/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
how was it done?, must have to bend the axles?
how can it be done with an alko torsion axle, one side of our trailer wears the inside of both tyres
facory
Georgia
Posted: 06/26/12 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Some axles, especially on toy haulers, have a slight arch built into them. As weight is added the axles will straighten out. It's much like a flat bed trailer that is high in the center to accommodate the anticipated weight. I found this out when I had the same problem with my trailer. I took it to a local trailer manufacturer and they explained it to me. As long as I am not adding a lot of weight (about 800 lbs. for a cycle) it will cause a little wear to the outside treads.
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
 > Axle alignment
