RV.Net Open Roads Forum: Fifth-Wheels: All about tires again
 > All about tires again
Gray Fox
Swansea Ma. USA
Posted: 06/26/12 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I have had no luck trying to get Michelin XPS Ribs The ones I could get have a DOT date of 2310. and they are 400 miles away. I can get some Cooper Discover HT Range "E" 10 ply. dated 0212. I saw them myself.Would this be a good choice. The axles are 7000 LBS.
Loaded tr. 12,350 last year at a cat scale 20,520 with truck.
Gray Fox
2005 F350 4x4 Diesel Lariat
2009 HH-LS 34.5 RLTG
Always keep moving so you don't seize up.
jim87vette
Arizona
Posted: 06/26/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Did you try Tire Rack?I just bought some tires for my Dually and they sent them to an installer close to me.really worked out well.the date code on my tires were like 2 or 3 weeks old.They were cheaper then going to tire shop and having them do the entire job.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
donn0128
Pronounced Ore-gun
Posted: 06/26/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
XPS Ribs are Not a good choice for 7K axles. You might consider upgrading to 17.5 inch tire wheel package for a bit more than the Ribs would cost you.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
JIMNLIN
out here
Posted: 06/26/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I did a 1-800 with Cooper some years back on which of their LT tires they recommended for my 11200 lb trailer. I was interested in the Discoverer but the only LT line they would recommend was their commercial tread SM II 16" LT E.
If your interested in the Ribs and can't find them you will get basically the same all steel casing tire in the Bridgestone R-250 which is a commercial grade tire but a bit lower in cost the the Michelin Rib tire.
The tires were talking about will give you 12168 lbs of capacity
'97 Park Avanue 28' 5er 11200 gvwr two slides
45Ricochet
North Idaho
Posted: 06/26/12 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
X2
No way I'd settle on a 2 year old tire, especially with the price of a Rib.
Note the weight capacity Jim listed. I realize not all 7k axles actually carry a full 7k lbs. Know your weights before putting a E rated LT tire on.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Cummins12V98
on the road
Posted: 06/26/12 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Put on a set of GY G614 G and don' look back. Use tire mfg tire inflation chart inflate 5 psi over loaded tire weight. Yea yea make sure wheels rate for the psi you will be running. I did this on my Avion that came with E tires and had several thousand trouble free miles.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
reddwar
Valley Center Ks. /Now Scotland SD.
Posted: 06/26/12 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of folks go with Goodrich Commercial tires as they are made by Midchelin & cheaper than Michelin XPS Ribs. I would not go with 17.5 unless you have $2,500 bucks setting around that you have no use for. If you want a little heavier tire you may want to look at a hankook F 19, it is a 750X16 14 ply, it is a commercial light truck tire. On our last rig came with GY G614 had real bad luck with them. Went with the 750X16 Hankook's only had one problems with them after we ate one day I did not look/check at my tires which I almost always do every time I would get in the truck, after running the G614's & it went flat & lost it. I think they are a 65 mph tire so if you run 75+ don't bother to look at them, I run 62-63 mph, Oh yes make sure that your rims will take the higher pressure as they go up to 105 psi.
red
http://www.fourwheeler.com/techarticles/wheels/129_1110_hankook_maxi_vantage_f19_trailer_tire/index.html
Red Birder
Retired and Traveling
Posted: 06/26/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
pecifications
Hitch Wt. 2,240
UVW 10,811
GVWR 14,500
NCC 3,630
GAWR 6,084
Brakes 12" x 2"
Tires ST235/80R16E
Model 34.5 RLTG
Width 96"
Height 12' 9"
Length 35' 9"
Furnace 40,000
Awning Opt. 17'
Water 70
Tanks 28/50/50
So, if your GAWR is 6084 like this spec data from NuWa site, and you can not find Michelin tires, then do what someone else suggested. Find Bridgestone Duravis R250 or R895. I believe that both of these are steel ply sidewall tires.
2005 Cardinal 29WBLX 5th Wheel
FastEagle
Taylors, SC
Posted: 06/26/12 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Red Birder wrote:
pecifications
Hitch Wt. 2,240
UVW 10,811
GVWR 14,500
NCC 3,630
GAWR 6,084
Brakes 12" x 2"
Tires ST235/80R16E
Model 34.5 RLTG
Width 96"
Height 12' 9"
Length 35' 9"
Furnace 40,000
Awning Opt. 17'
Water 70
Tanks 28/50/50
I’ve been opposed to this kind of post since I started posting tire information.
I have no idea why people will take it upon themselves to post and support information that violates standards and safety procedures.
In the quote above I’ve changed a number to the color red to highlight the figure I’m going to write about.
NHTSA writes and enforces safety standards. They say replacement tires MUST have equal or greater load capacities than the OE tires being replaced.
Industry standards are all supported by tire manufacturers, the TRA and RMA.
The DOT says vehicle manufacturers are responsible for setting the RV trailer’s GAWR, the tires/rims selected for the GAWR and the recommended tire pressures. Once set in motion and displayed on the vehicle’s certification label that information becomes the minimum standard for that trailer. That doesn’t mean an owner is locked into the OE tire size or design. It just means your replacements have to equal or be greater than what is depicted on the labeling.
Of course as an owner you can do as you see fit. You are responsible. As a recommender of an unsafe recommendation here on the internet I doubt you can be held accountable for that action. I’m not picking on this particular poster. I’m just using the well displayed information in the quoted post to get my point across. Just maybe someone making this sort of recommendation has not understood how the industry fits all the pieces together.
To stem your curiosity you should consult with the vehicle manufacturer or tire manufacturer. Tell them exactly what your certification label/tire placard displays and get some feedback.
FastEagle
Dickinson, ND
rattleNsmoke
Western Conn.
Posted: 06/26/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
I installed the Cooper SRM II LT 16's a month or so ago and they are well worth the $$. My trailer is placarded for LT's altho it came stock with ST's. I called Forest River and they basically told me it was whatever they had available that day and admitted the 'Offshore' tires were cheaper to use. Screw that!
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
