RV.Net Open Roads Forum: Boondocking with a generator
Open Roads Forum  >  Class B - Camping Van Conversions  >  General Topics
 > Boondocking with a generator
Mafman
Qc
Posted: 06/26/12 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Ok so the plan is to boondock for a few days next weekend. We're headed to Northern Quebec and expecting cool nights, so will be bringing our Yammy 1000w generator to help the battery run the furnace. I know I should get at least one night from the battery, but after that who knows.
My question is what's the best setup? Plug the TT directly into the genny and fire it up once in a while or should I use the charging plug from the genny directly to the battery?
Thoughts?
2013 Avenger 28BHS
2009 Puma 19FS
2012 GMC 2500 6.0L- 3:73
2009 GMC Sierra 5.3L - 3:42
EAZ Lift - proStar Ultra
DW, 2 DKs
2oldman
Winchester WA
Posted: 06/26/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
choice A usually works.. and with (I presume) only 1 battery, your converter won't overload the genny.
1mtnman
Colorado
Posted: 06/26/12 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
You would reap more benefit and quicker charge by having a battery charger plugged into your generator and connected to your battery. The charger should be capable of charging at 25 amps.
Mafman
Qc
Posted: 06/26/12 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Correct 2oldman - one battery only.
pianotuna
Regina, SK, Canada
Posted: 06/26/12 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Assuming a 3 stage converter in the RV plugging in the RV is your best bet.
You could bring along an outboard battery charger--but I find I have all together too much stuff as it is!
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
opnspaces
San Diego Ca
Posted: 06/26/12 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, plug the rv into the generator. You can also bring along a stand alone battery charger to run from the generator. Probably the slowest method is to use the battery charging feature on the generator.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
skipnchar
Topeka or somewhere else
Posted: 06/26/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Your best bet will be to start the generator and plug a stand alone charger into it to charge your batteries. that way you don't have to run the gen set all night.
