ford truck guy
Pennsylvania
X3 on slip plate... Joe
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
Al B
Cowtown
I will also agree with the statement of grease collecting dirt in such an open area. BUT... I'm not so sure the dirt will wear out the screw in my life time. So I'll trade the convience of quiet, easy threading, for dry, squeeky WD-40 or minimal dry lube, anytime.
I guess if you really didn't like the look of the "dirt", it could be cleaned off annually as regular maintenance and new stuff applied... Just a thought tho.
Cummins Powered
Artemus Gordon
Redding California
"Dry graphite spray" is what I was told to use. Get it on Amazon!
Dave H M
IL
my vote would be for slip plate.
Locally the farmers use it on a lot of stuff - even the bottom of the gravity empty grain wagons. Stuff just don't cling to it and it is slippery.
netaq
Atlanta, GA
I remember that in the NTSB report on the Alaska Airlines flight 261 crash, they did a big analysis of how clean grease, dirty grease, & no grease affected wear of a jack screw. Bottom line is, grease is better than no grease, and dirty grease is not a significantly worse lubricant than clean grease.
See pp 86-87 (page 100-101 of pdf):
http://libraryonline.erau.edu/online-ful........ircraft-accident-summaries/AAR02-01S.pdf
2012 Ford F-250 XLT 6.2 FX4
2012 Keystone Cougar HC321RES
AC09
Yuma
Not meaning to hijack the thread are we talking about the front stabilizer jacks?? Where is the grease needed? My OM doesn't have any info on this? Thanks
bpounds
Whittier CA
AC09 wrote: Not meaning to hijack the thread are we talking about the front stabilizer jacks?? Where is the grease needed? My OM doesn't have any info on this? Thanks
The front jacks are commonly called the "landing gear". We were discussing the rear stabilizer jacks. Mine are BAL scissor style jacks and have leadscrews.
However, I do pull the caps off my landing gear legs and put some lube on the bevel gears. I would do the leadscrews if I could get to them without pulling the leg out. But I can't, so lubing the bevel gears will have to suffice.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
laknox
Arizona
Grease? Lube? We don't need no steenkin' lube on our jacks! :-) I've never lubed mine and they work just fine. Tap 'em with the screw handle to knock off the worst of the dirt and they go out and in without a problem. I doubt they'll ever wear out since they don't get used all that often. :-(
Lyle
1936 John Deere Model A
