RV.Net Open Roads Forum: Towing: Reese Dual Cam and New TT
Search only in Towing
Open Roads Forum  >  Towing
 > Reese Dual Cam and New TT
mjost
St. Louis, MO
Posted: 06/27/12 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Ok, so I ordered my new TT yesterday. It is a 2013 Passport 3050BH.. Approx weight is going to be 6000lbs (5500 is the sticker, so i figured 500 for the accessories, etc). Anyway, I was thinking of a Hensley hitch, but the cost is more than I really wanted to spend. I had an Equal-I-zer on my old unit. I wasn't really happy with it. Bent Pins, lots of noise at slow speeds.
Anyway, been doing a ton of reading, and it just depends who you talk to, so I figured talk to someone who has a similar setup. Is anyone else using a F150 Eco 157" WB 4x4 with a similar hitch/weight setup. If so, what are your thoughts.
netaq
Atlanta, GA
Posted: 06/27/12 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Lots of people use Reese dual cam including me. Most people like it, some really hate it. I have the 1200# trunnion model, but all the dual cams are similar in operation. It pops a little when making sharp corners, but that's a consequence of having sway control. You get used to it. I like the DC hitch, works perfect for my current needs.
2012 Ford F-250 XLT 6.2 FX4
2012 Keystone Cougar HC321RES
netaq
Atlanta, GA
Posted: 06/27/12 08:42am Link  |  Quote  |  Print  |  Notify Moderator
And, that's a fine lookin' RV you picked out!
APT
SE Michigan
Posted: 06/27/12 08:48am Link  |  Quote  |  Print  |  Notify Moderator
My TT is 5500 pound's according to the yellow sticker. I estimate I'm closer to 6500 pounds ready to camp. Love my Reese strait line when it's adjusted well. Rock solid towing at 75mph if I want. But when it's off, towing sucks. If you are willing to invest some time in learning how to adjust it, go for the Reese.
2012 VW Passat TDI
eric james
Sioux Falls, SD
Posted: 06/27/12 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Ditto. Using 1200 trunnions too.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
jerem0621
Sequatchie, TN
Posted: 06/27/12 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Dual cam does great when it is adjusted right. If its wrong then you will know it for sure.
I had to have dual cam. Now It's sitting In my bucket of RV parts on my workbench. I'm back on dual friction sway control. It's just more reliable in my experience. (pulling 1400 miles with dual friction bars over the next two weeks)
However DC is a great form of sway control when it is dialed in. You will either love it or hate it.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
afob3
Maryville, TN
Posted: 06/27/12 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Love ours... Key is proper setup. Took me a few hours of tinkering with the directions until I was happy.
Really like that there is no issue with backing up & it doesn't groan when wet like the friction set up I had did.
2012 Koala 25DS
2011 F150 Ecoboost SuperCrew with Max Tow Package
www.familyobrien.net
dodge guy
Bartlett IL
Posted: 06/27/12 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
5500lbs dry will be 6500 ready to travel! always add a minimum of 1200 lbs to the dry weight, figure on 800 lb bars. I have the DC and it performs flawlessly. I had the same DC on my old Dodge conv. van with a 28foot 6500lb trailer and it did great.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
fla-gypsy
North Florida
Posted: 06/27/12 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
The Reese Dual Cam is the best hitch/sway control system I have ever owned. I installed it and adjusted it myself following the printed instructions and thought it was not that big of deal. Took two quick adjustments to dial it in and man ol man does it make a difference. The TT behaves beautifully now. BTW, mine is a 10k GVWR and I use the 1200/12000 lb set up.
mbopp
Henrietta, NY, USA
Posted: 06/28/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I spent a few hours dialing mine in after the "dealer" installed it. I even had to re-drill and re-mount a cam bracket on one side.
But - once I got it set up right I like it.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
