RV.Net Open Roads Forum: Tow Vehicles: Oil change evey 15 YEARS.
Search only in Tow Vehicles
 > Oil change evey 15 YEARS.
45Ricochet
North Idaho
Posted: 06/27/12 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Here's a good link for you Navydood
Clicky
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
firemedic08
North Central PA
Posted: 06/27/12 11:21am Link  |  Quote  |  Print  |  Notify Moderator
In the Army we dont do oil changes. Every so many Mile the Computer tells us to do an oil sample. If the Sample comes back good we drive on of it come back contaminated, we fix it and replace fluids.
Donnie
1994 Chevy 2500 Extended cab
1980 sunline,
Gale Hawkins
Murray, KY
Posted: 06/27/12 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Blows a hole in the fact annual oil changes are required does it not. I wish I had tested the 17 year old oil I drained out of the 18 HP B&S home generator.
Hannibal
Gas Station
Posted: 06/27/12 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
People actually believe this stuff. Do your one Blackstone lab tests. Even with the best synthetic oils, viscosity increases to out of range in less than 20k miles even with topping off as it gets low on the dip stick.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
RVUSA
Orlando, FL, USA
Posted: 06/27/12 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
It's obvious why they are anonymous. Total fabrication.
Gale Hawkins
Murray, KY
Posted: 06/27/12 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
No they just happen to match the standard numbers one for one.
whisperide
Golden Spike area
Posted: 06/27/12 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
Suspicious, but maybe that's where the standard came from?
Oil changes aren't about time or mileage, they're about usage / contamination. Lots of really short trips in cool humid weather will result in condensation not getting cooked away, as one example.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
NavyDood
NW of DFW
Posted: 06/28/12 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Say what? No believing on my part because I have facts backing up my OCI's. I run Amsoil AME 15w-40 for 25,000 miles or one year. If I don't hit the mileage first I extend past a year (2-3 months if needed) to hit 25,000 miles. I don't have to add any oil between oil changes and I do not make oil either. Keep on being a non believer.......
New Amsoil AME viscosity is 14.2 @ 100°C cSt.
Past four oil changes using Amsoil AME in order of oldest to newest.
2008 viscosity was 13.3 @ 100°C cSt.
2009 viscosity was 13.4 @ 100°C cSt.
2010 viscosity was 13.3 @ 100°C cSt.
2011 viscosity was 13.5 @ 100°C cSt.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
RVUSA
Orlando, FL, USA
Posted: 06/28/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
You are comparing apple to oranges.
You have a diesel. Diesel fuel dilutes engine oil less than gasoline.
You are running synthetic. Synthetic viscosity changes less over time than dino oil, and it changes even less from fuel dilution than dino oil.
Do you run the full 25000 on the same filter?
45Ricochet
North Idaho
Posted: 06/28/12 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
You obliviously have never seen a 6.4L PSD report Same with the early 6.7 Cummins. Lots of owners are down to a 5k mile oil change regiment because of making oil. You can't paint with that wide of brush.
