Our Roadtrek Sprinter is plugged into the house while we are home. When I unplug it, should I unplug the Roadtrek first or unplug from the house first? Does it matter?
Tanya6520 wrote: Our Roadtrek Sprinter is plugged into the house while we are home. When I unplug it, should I unplug the Roadtrek first or unplug from the house first? Does it matter?
Unplug the supply first. Same as you do at a camp site. If you unplug the rv first you will be leaving a live wire on the ground.
Good sound advice.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
If possible always shut off the breaker before connecting or disconnecting anywhere, campsite or home. This nulls the original question from OP but ultimately prevents arcing that could damage either the plug or the receptacle. This also eliminates the problem identified by joelc above.
'04 Cross Country 35' w/300 Cummins
'05 Sebring CV on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/TWIN H-POWER & 5 lbs of BG the Yorkie
Members of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
As above, TURN OFF BREAKER first, then other order doesn't matter.
Be sure to ALSO ALWAYS have CG breaker off when connecting or disconnecting shore power. Your power cords plug will last MUCH longer that way, as will CG socket.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories I can't be lost because I don't care where this lovely road is going
Chuck&Gail wrote: As above, TURN OFF BREAKER first, then other order doesn't matter.
In the event you are at a CG, yes the breaker goes first, but as noted here, I think they were at home. The breaker could control other important appliances if not dedicated.
At home I do not shut off the circuit breaker but I do unplug from the house first - for one thing it is easier to pull the 15/20 amp plug on the adapter from the wall than to pull apart the 30 amp plug and socket. At a campground, I always shut off the CG circuit first - before plugging into it and before unplugging from it.
