RV.Net Open Roads Forum: Truck Campers: Flooring ideas
 > Flooring ideas
jtlingo123
Snoqualmie, Washington
Posted: 06/27/12 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in the process of getting some stick on vinyl flooring for my camper project from Amazon, they have some great deals on flooring if you don't mind waiting a couple of days. Hopefully this will do the trick! I got 20 square feet for 20 bucks after shipping.
Josh Lingo
Snoqualmie,WA.
Photomike
Southern Alberta or where the camper is parked!
Posted: 06/27/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I did the vinyl floor and then cut a piece of carpet to fit in. This way I have a choice. Has been useful a couple of times, a water leak soaked the carpet so pulled it and let it dry, another time we went to a beach so left the carpet at home - easy clean up.
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Homemade Cargo Trailer for hauling supplies
Advanced Elements Kayaks
Border Collie Guard Dog
raggmann
Botha,Alberta
Posted: 06/27/12 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the ideas.
I'm still a couple weeks away from getting to that point so I've got time to explore options.
I kinda like the idea of stone/tile now, thanks to . Haha
Live like you ain't afraid to die and don't be scared, just enjoy your ride
1993 Dodge W250 CTD Club Cab with a 4" lift & 35's
1975(?) Skylark 9'TC
2009 Harley-Davidson Softail Deluxe
TGarrett
TN/SC
Posted: 06/27/12 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure to think about the thickness. One of the reasons I think it is an issue is my counter extension is cocked and won't go flush against the cabinet which leads me to believe the flooring is thicker than the original. Where my slideouts go in and out you can see where it has rubbed the floors. It still looks good overall for an used coach but I want to tear it out and see if what I think is water damage actually is. So just keep that in mind when you select your flooring I know I will.
I am interested in how well you do with this as my coach I bought a few weeks ago has some underfloor issues and it looks like they installed real hard wood, but I think that is where the extra thickness is coming from. I know laminate and stuff is/can be thinner. Plus whoever did the remodel probably didn't consider it themselves till after the fact if they ever even noticed it.
Garrett
2004 Fleetwood Expedition 38N
Full Timer
Toad(still to be setup) 2011 Jeep Rubicon
2nd (to be put on double trailer with 1st when moving) 2008 Honda S2000
cinca
CA
Posted: 06/28/12 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Adding to your reference list
A post by Atchafalaya_man on installing his floor.
nycsteve
NY
Posted: 06/28/12 05:38am Link  |  Quote  |  Print  |  Notify Moderator
I wouldnt use carpet, once dirty its hard to get it looking fresh again. Plus it would hold dog and other oders. I've seen a vynel product in Home Depot called (I think) Alure. It looks like it floats and sticks together not to the floor. I checked the samples on display, its very durable. What i saw was a good looking wood imatation. That would be my route, if I wanted a soft spot for the dog, I'de use either an area carpet or bed, but it would need to be able to be washed.
Just my 2 cents.
Im in Depot in 45 minutes, I'll look again for brand etc. if anyones interested.
AISURFFISH
BERLIN MARYLAND
Posted: 06/28/12 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I had to recover floor due to some soft spots. I cut out the exact floor plan with a sheet of 3/4" plywood then used the faux tile with thte sticky backs. Then I trimmed it with a durable poly rope held in by brads and glue.
* This post was edited 06/28/12 07:03am by an administrator/moderator *
2004 F350 V-10 GAS CREW CAB SHORT BED BLACK
THE LANCE MAX 881 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF BEER
A.M.S.A. MEMBERS HIM 1025/HER 1026/JUNIOR 93
MID ATLANTIC TRUCK CAMPER RALLY INFORMATION PAGE
jtlingo123
Posted: 06/28/12 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Hi AISURFFISH,
I was wondering how the stick on vinyl worked out, I am in the process of using this in my camper and with four kid I'm hoping it holds up pretty good?
Thanks, Josh
garryk6
Kodiak, AK
Posted: 06/28/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Just my 2 cents.
Hey nycsteve,
The Allure brand has two types of flooring. The first type they came out with is the one you are talking about. It is a floating floor, but sticks together with a peel-back tape. It works alright, but not as well in the high traffic, and/or high moisture areas. the glue can let loose, and then the pieces separate.
The second type they came out with is what I mentioned earlier. It goes together like laminate flooring. It is still a floating floor. But does not work loose like the sticky/glue type. The military has approved it in their housing, as it is very durable, and takes much less time to remove and install when replacement is needed. You can even undo it back to a damaged piece, and just replace one piece, and then put it all back down. I bought a box to do my camper, just havn't made the time to install it.
I hope this helps,
Garry in Kodiak, Alaska
Garry K
Wife + 4 kids
Retired Military Family.... Alway's on the move....
2002 F350 CCSB 5.4 6spd 4x4 in AK
1966 Avion C-10 Truck Camper
AISURFFISH
BERLIN MARYLAND
Posted: 06/28/12 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Josh... They worked great i did it it the depth of winter and no heat and it was hard to install and stick but this summer everything has fallen into place and looks great as you can see.
 > Flooring ideas
