RV.Net Open Roads Forum: Tech Issues: Trying to decide on portable generator
 > Trying to decide on portable generator
Artemus Gordon
Redding California
Posted: 06/27/12 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yamaha 3000 with boost. Works great, will power one of my two 15k air units . Buy the remote start, worth every cent!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
SledHedEd
mass
Posted: 06/27/12 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Red, wrote:
SledHedEd wrote:
We rarely use the ac even in the campgrounds with elec.
When you have to use the air conditioner . . .
Move to somewhere that's cooler.
We got RV's with wheels !
Red, *<(:{)-
Like I said, we RARELY use it. Something like 2 times in the past 3 years. Thanks for the helpful input.
Enjoying what life brings me everyday.
laknox
Arizona
Posted: 06/27/12 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
SledHedEd wrote:
I'm thinking we'll be good with a 2k. We rarely use the ac even in the campgrounds with elec. I have seen other brands like Generac and Ryobi and I was wondering if they are as quiet and dependable. I know the Honda and Yamaha are the best but they are also quite expensive.
Don't forget that most of the cheaper models are true generators, whereas the more expensive ones (of all brands) are mostly inverters, and only run fast enough to handle the load on them. This is one reason they're more quiet and efficient. Don't get fooled, though. There are some Yamaha (and other brands) models that use a high-torque, low rpm constant-speed engine. Yes, they're quiet, but are much less efficient since they're running at full speed, all the time.
Lyle
1936 John Deere Model A
JoeWebPage
Palisade, Colorado
Posted: 06/27/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a Champion generator at Cabelas and was impressed with it until we took it boondocking up around 10,000 feet. It would run for about a minute and then just die off. A call to the factory and they say they never tested them at that altitude. We exchanged it for a Yamaha 2000 (Cabelas carries both) and discovered that it was much quieter, ran longer, and handled just about everything we threw at it at that altitude. Didn't try the AC, but at that altitude you don't need AC.
My camping companion has the twin Hondas and honestly, I don't think there's really difference between the two. FWIW, the Yamaha is easier to drain the fuel at the end of the season.
2012 Durango 2500 325RL, Remote jacks, 5500 Onan, TST TPMS
2004 GMC Duramax, USAF retired
mena661
Posted: 06/27/12 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yamaha EF4500. Leave it in your truck bed.
Trojan L16 6V's 740 Amp-hours
zztinker
Central California
Posted: 06/27/12 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
We use the Champion 2000i (the red one from Costco $489.00) and it works great. It runs everything but the A/C. If you want the best the Honda or Yamaha is the way to go, however if your like me and use it 10 or 15 times a year, the Champion 2000i will get the job done.....
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
christopherglenn
a little over an hour from Yosemite
Posted: 06/27/12 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
I tend to get generators that are to big to carry, tends to make it hard for them to grow legs. That is why I have a honda 3k, I can lift it in and out of the bed, but forget carrying it more then a few steps my yourself. You also need to decide how you are going to secure it before you buy it, some are easier to secure then others.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Artemus Gordon
Redding California
Posted: 06/27/12 11:24pm Link  |  Quote  |  Print  |  Notify Moderator
One last thought. Remember larger fifth-wheels like mine, have 90 amp converters. Even charging big battery banks and other electrical appliances can draw lots of power. Learned that the hard way. I bought a meter and found going bigger was better!
David_and_Chris
NYS Capital District
Posted: 06/28/12 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I use a champion 4000W from Tractor supply.Champion 4000W
I had a shelf installed in 5vr and just slide out when I want to use the generator. The generator is currently mounted on 4x4's so it will not slide front to back.
David
David
laknox
Arizona
Posted: 06/28/12 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
I still want to put a receiver on my FW and just hook up to my dad's 25kw Multiquip. :-) It's not much louder than a Honda 3000 and a helluva =lot= quieter than my old Y2K Generac 3500. 'Sides, I could charge a bunch of other campers to hook up. :-)
Lyle
