RV.Net Open Roads Forum: Tire Pressure Monitor worth buying for gas savings?
 > Tire Pressure Monitor worth buying for gas savings?
josten367
Columbia, MO
Posted: 06/27/12 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, those who have a tire pressure monitoring system, is it worth having one and does it pay itself off in gas savings?
Tire Pressure Monitoring Systems
This an example from CW.
2012 Palomino Puma Bunkhouse 5th Wheel 295KBH
2003 Chevy Silverado 2500HD Crew Cab 4x4 Gas with Flowmasters
B&W Companion 5th Wheel
filthy beast
New Mexico
Posted: 06/27/12 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I think the major use for the TPMS is to avoid damage to the rv in case of a tire blowout. I had two tire blow within 5 miles of each other before I bought mine. Even without a TPMS, tire pressures should be checked frequently.
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
1 Damnatian!
You cannot make things idiot proof, you can only make them idiot resistant.
Chuck&Gail
In the Colorado Mountains
Posted: 06/27/12 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Worth having, IMO yes. Saves gas, IMO no.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
JJBIRISH
Butler, PA, USA
Posted: 06/27/12 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I carry and use a gage in every vehicle and doubt I would save a dime on gas from their use…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
powderman426
ohio
Posted: 06/27/12 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Save gas? I doubt it.
Save your life??? Maybe
Save you aggravation?? Definitely.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
tvman44
Southwest Louisiana
Posted: 06/27/12 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not likely to save enough gas to ever pay for itself. But to warn you of a tire going flat or a blow out and minimize damage, worth it's weight in good+.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
scarpi
Phoenix
Posted: 06/27/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
My 09 PW has a TPMS and at first I couldn't understand why I was getting a TPMS warning on my dashboard that would not turn off. I thought the TPMS had a problem because all four of my tires were at the proper inflation level per my tire gauge. So I thought, could it be my spare, and guess what, the spare was way low in air pressure. I thought it was really cool that even the spare tire was monitored. I generally check the air pressure in my four tires once every couple of weeks even when it is parked in my driveway, but I did not check the spare. So now occasionally I check the spare also. The TPMS system saved me from perhaps being stuck on the road with a spare that was way low in air pressure. TPMS is a good idea.
RAS43
Littleton,CO
Posted: 06/27/12 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
I totally agree!
B's Bunch
Shelbyville, TN. USA Why live any where else?
Posted: 06/27/12 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Do they have internally mounted devises like on new cars/trucks or all are mounted on the valve stem. If your toad has them factory installed would they be able to talk with the monitor on the motorhome. Seems technology is here to be able to accomplosh this without much expence. Just thinking Larry
Larry,Brenda,Travis,Jarred & MEME the Boston Terror TheBunch 2011 American Coach Revolution 42T
josten367
Columbia, MO
Posted: 06/27/12 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Would it be good to have it on the tow vehical?
