crabbyman
delaware
hello fellow rvers have a question for someone to answer my problem is when im hooked up to my truck im getting my running lights to light on the trailer but i cant run my reefer on gas no electric on the inside of trailer but when i get to the campground im fine please help me thanks
Turtle n Peeps
California
Could be lots of things but I would say your battery is junk or the connections to the battery are bad.
outside the fire"
clearnetedm
Alberta
Not sure what kind of vehicle you have but for my ford there was a fuse I needed to add to my main fuse panel to get it to provide power to supply the RV and battery. By default if will just power the trailer signal lights, brake lights, etc.
2008 Ford Expy EL
2012 Rockwood 2601S
sch911
Rochester Hills, MI
Fridge needs 12V to run. Do you have a battery installed in the TT? Is it charged? As stated there should also be a charging line from the TV.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
usmc616
Orange County, New York
My battery died this winter. When my TT was hooked to my TV I had running lights but no inside lights. Once I replaced the battery I had inside lights as well as running lights. I would suspect the battery is bad from my experience.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
Old-Biscuit
Across the USA
Your truck battery only supplies power for trailer lights (running, turn, brake), trailer brake system and a charge line for trailer battery......minimum charge.
Your trailer battery supplies power for inside the trailer and for the trailer brake in the event of trailer/truck separation.
Your converter when plugged into AC power source supplies power for inside trailer and charges your trailer battery.
From the sounds of it..your trailer battery is:
BAD...replace
Not getting a charge...check converter output/function
Is turned off........isolation switch in off position
You need to find which and correct......
You NEED a good fully charged battery for the 'emergency brake function' just in case the trailer/truck should ever get separated while towing....SAFETY.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
