RV.Net Open Roads Forum: Tech Issues: Onan 4KY generator problem
 > Onan 4KY generator problem
Redy2GO
North Georgia
Posted: 06/27/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Onan 4KY series generator that has been running fine, except recently it started to make an intermittent clicking/ticking sound, but still ran. However, on this trip while it was running it suddenly just stopped and will not restart. There is an error code of 36, which seems to indicate a fuel problem, but the motorhome fuel tank is full. To all of the Onan wizards on RV.Net, do I have a bad fuel pump, or is there something else I should be looking at? Any/all help will be appreciated.
Bill and Jann
"Sindhu" the Balinese cat on a leash.
2005 Jayco Greyhawk 29GS
96Bounder30E
America is my home!
Posted: 06/27/12 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
The ticking sound.........sounds like a dry fuel pump to me.....my guess is you have a fuel line problem......possibly back at the tank....
Try running the genny from a portable gas can.....disconnect the fuel line that goes to the pump and stick in in the gas can....
If it runs fine then look closer at the rubber fuel lines.....
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
CloudDriver
New Jersey Shore
Posted: 06/27/12 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
If your Onan 4KW is similar to ours, it has a start switch with a prime function at the generator. Holding the prime side of the switch will run the fuel pump without cranking the starter so you can hear whether the pump is working. A working pump makes a buzzing or humming type sound.
2003 Winnebago Minnie 24F - Ford E-450
PatrickA51
Lost
Posted: 06/27/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Onan 4KY also. You might look here....Onan Troubleshooting
PatrickA51
Lost
Posted: 06/27/12 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
You also might look here....For more info
Redy2GO
North Georgia
Posted: 06/29/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestions, but I think I will have to wait until I get home to give them a try. Appreciate the help.
