RV.Net Open Roads Forum: Class A Motorhomes: washer/dryer combo
 > washer/dryer combo
SKIPCAROL
COSBY,TN
Posted: 06/28/12 07:05am Link  |  Quote  |  Print  |  Notify Moderator
We are toying with the idea of replacing our stovetop/oven with a washer/dryer combo. Y'all probably think we're crazy but we never use the oven and rarely the stovetop. In fact not once since the first of this year. If we can't micro, toaster oven, outside grill, George, or go out, guess we'll go hungry! We've been workamping for a year now almost full time and have used laundromats. The campground where we are now has 9 washers for 1000 sites...500 temps and 500 permies. Hard to get to one and the nearest laundry is 30 miles away.
Wanted to get your opinions on these machines as they are expensive but on the other hand sometimes convenience pays for itself especially if they work well etc. We have an RV guy here in town that can do the installation. It would have to be wired into the water heater breaker so we would have to use gas when we used the washer. So do you like 'em, use 'em, reccommend a brand etc.? Thanks, Skip
Carol, Skip & Buddy the Mutt
2005 Four Winds Hurricane 32R
2008 Chevy HHR Toad
bsinmich
Holland, MI
Posted: 06/28/12 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a 30 or 50 amp coach? I think that would really make a difference if you can't run the AC while using the W/D.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
rr2254545
Minnesota/New Mexico
Posted: 06/28/12 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Talk to others, we had a combo unit in our 2008 MH, small loads, took forever to do a load and clothes were wrinkled. New MH has stacked separate units much better.
Save your money
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
paulcardoza
Southeastern Massachusetts
Posted: 06/28/12 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Would never buy another coach without one! We have a Splendide.
Pros -
Does a terrific job washing. Uses little water and little detergent. Small and convenient.
Cons -
Requires a very SMALL load if it's going to dry properly. We tend to hang our shirts/pants out to dry whenever possible, so we can do a larger load. Sometimes FOLDING clothes before drying helps a lot! (TRUE)
Suggestions -
ONLY consider a vented model, as the un-vented versions are even WORSE when it comes to drying.
Keep up with the laundry every day, or you'll become frustrated with the small load capacity.
Use the express wash setting, if your's has it. The cycle is much shorter and it cleans perfectly.
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
klm
SIOUX FALLS, SD
Posted: 06/28/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I have the combo unit and love it, but you need to understand it's limits. Small loads, and takes lots of time - for 1 or 2 people - great - large family - maybe not so much. And yes, definitely a vented unit. You would have to measure your space, is it plumbed, electric outlet?? Not sure about having the w/d under a lp stovetop?
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
Mookie5362
Maple Valley, WA 98038
Posted: 06/28/12 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Check out wonder wash portable washer http://www.laundry-alternative.com/
steveownby
Cosby, TN
Posted: 06/28/12 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Pros -
Cons -
Suggestions -
X2
Ours will do 4 pair of jeans in a load and if you take them out and spread them on the bed as soon as the dryer stops it minimizes wrinkles.
Splendide is the brand and the vented model is the way to go.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
ricklord2001
Woodstock, Ga
Posted: 06/28/12 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Everything has been said above but I really like mine. I get up every morning and start it. So pretty much do a small load a day when we have full hookups.
Probably wouldn't be much good during boondocking as it uses a bit of water and would empty your water tanks and fill up you grey water fairly quickly.
We also rarely use the stove as our microwave is also a convection oven which the DW has come to love.
Ivylog
Blairsville, Ga. USA
Posted: 06/28/12 08:33am Link  |  Quote  |  Print  |  Notify Moderator
You should be able to find a slightly used one for 1/2 C Worlds price. Try and find a vented Splendide 2100. Here is what you can often find on CraigsList.
* This post was edited 06/28/12 08:42am by Ivylog *
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
SKIPCAROL
COSBY,TN
Posted: 06/28/12 10:55am Link  |  Quote  |  Print  |  Notify Moderator
We do have a 50 amp coach, would eliminate the stovetop & oven and there only 2 of us. The RV guy in town here says theres no problem to do it (he has a great reputation around here...we're in Urbanna VA right now). Sounds like a plan and can order a Splendide from PPL and get free frt for $1187 and have it delivered to the RV guy.
